Heat Absorbed during a process on an Ideal Gas
5 replies · 22K views · last reply
adammw111
0.21 x 10-3 kmol of ideal gas occupy a volume of 5.0 x 10-3 m3 initially at a pressure of 1.2 x 105 Pa and temperature T.
The volume of the gas is first decreased to 2.0 x10-3 m3 at a constant pressure of 1.2 x 105 Pa, and then the pressure is increased to 3.0 x105 Pa at a constant volume of 2.0 x10-3 m3.
For this process, calculate:
A) The Work done on the gas
B) The Heat absorbed by the gas
ΔU = Q - W
(where ΔU is change in internal energy, Q is Heat and W is work done by the gas)
U = n NA ([itex]\frac{1}{2} m \overline{v^2}[/itex]) = [itex]\frac{3}{2} R T[/itex]
where U is internal energy
W = p ( V2 - V1 ) (for isobaric process)
W = 0 (for isovolumetric process)
A rough P-V diagram would look like:
[PLAIN]http://img695.imageshack.us/img695/5465/pvdiagram.png
A) Work done on the gas.
Work done is area under P-V curve.
W = p (V2 - V1) = - 1.2 x 105 x (2.0 x 10-3 - 5.0 x 10-3) = + 360 J
B) Heat absorbed by the gas.
ΔU = Q - W, therefore:
Q = ΔU + 360
However I don't know how to find ΔU and seem to be stuck.
You can calculate the internal energy from the temperature. Use the ideal gas law. How does the temperature change between the initial and final states?
ehild
Using [itex]\frac{P_1 V_1}{T_1} = \frac{P_2 V_2}{T_2}[/itex] (ideal gas law):
[itex]\frac{1.2 \times 10^5 \times 5.0 \times 10^-3}{T_{initial}} = \frac{3.0 \times 10^5 \times 2.0 \times 10^-3}{T_{final}}[/itex]
[itex]600 T_{initial} = 600 T_{final}[/itex]
[itex]T_{initial} = T_{final}[/itex]
Therefore as an isothermic process (constant temperature), ΔU = 0, Q=W.
So Q = 360 J.
Is this correct? The answers I have for this sample exam give -360 J instead.
W is the work of the gas. As the volume decreases in the first step, the work of the gas is negative, W=-360 J. At the same time, Q is the adsorbed heat. ΔU=Q-W(gas)=Q-(-360J)=0 --->Q=-360 J. Some external force does work on the gas, and the gas transfers heat to the surroundings.
ehild
I get it now...
I was getting confused because the question asked work done on the gas when my formulas are for work done by the gas, and so I used the wrong number/sign in the second part. Your explanation makes sense.
Thanks, ehild.
adammw111 said:
I get it now...
Thanks, ehild.
You are welcome.
The First Law of Thermodynamics states that the internal energy increases by the amount of heat added to and by the work done on the gas: ΔU=Q+W. If the work is done very slowly, so the gas is very nearly in equilibrium with the external force, W=-PdV=-Wgas.
ehild
