Heat and final temperature question
4 replies · 9K views · last reply
kitkat
I am stuck on this problem...
What would be the final temperature when 100 g of 25 degree C water is mixed with 75 g of 40 degree C water?
I know that mc?T gained = mc? T lost
so (100g) (1.0 cal/g C) (Tf -25) = (75g) (1.0 cal/g C)(40 degrees - Tf)
Where do I go from here?
any push in the right direction would be great.
Kat
100g/75g = 4/3 = (40 - Tf)/(Tf - 25).
If I push you for such a small thing you will fall down dear kid.
Generally take this as a formula when same object of different amounts at different temperatures are kept in contact with each other and the temperature of equilibrium temperature is asked - M1/M2 = dT1/dT2.
Anyway do you really need a push to solve the above equation?
i guess so
I guess I need to be hit in the head with a hammer cause I just can't "see" it.
My teacher gave me the following formula
and I just can't see first what the heck Tf stands for, where the 1.0 cal came from an how to solve it at all. I get to this point and then falter.
With regards to [itex]T_f[/itex] think about it logically. Go through each parameter in your equation. [itex]T_f[/itex] is the only unresolved variable and therefore must be the thing you are trying to calculate.
As for the 1 cal/g C, this is the specific heat capacity of water. It is usually given in the question or on a data sheet.
It was set up wrong!
I figured it out!
The problem should be set up like so:
(100g) (1.0 cal/g Co ) (Tf- 25 degrees) + (75g) (1.0 cal/g Co) (40 degrees - Tf) = 0
Resulting in this:
100Tf – 2500 + 75Tf – 3000 = 0
175Tf = 2500 + 3000
175Tf = 5500
175Tf/175 = 5500/175
Tf = 31.4
I knew something was missing! Yea! I'm not dumb! Thanks to those who tried to help.
Kat
