Heat capacities and negative temperature
The discussion centers on the relationship between heat capacities \(C_P\) and \(C_V\) in thermodynamic systems, particularly in the context of negative temperatures. It is established that \(C_P\) is generally greater than \(C_V\) due to the mechanical stability condition \((\frac{\partial V}{\partial P})_T < 0\). However, the conversation highlights that quantum systems with only two energy levels can exhibit negative temperatures, challenging traditional thermodynamic principles. The implications of negative temperature on heat capacities and thermal equilibrium are also explored.
  • Understanding of thermodynamic principles, specifically heat capacities \(C_P\) and \(C_V\)
  • Familiarity with the concepts of mechanical stability in thermodynamic systems
  • Basic knowledge of quantum mechanics and statistical mechanics
  • Awareness of the relationship between temperature, entropy, and free energy
  • Research the implications of negative temperature in quantum systems
  • Study the relationship between heat capacities and mechanical stability in thermodynamics
  • Explore statistical mechanics definitions of temperature and their applications
  • Investigate the behavior of systems with negative temperature in relation to thermal equilibrium
Physicists, thermodynamic researchers, quantum mechanics students, and anyone interested in advanced thermodynamic concepts and their implications in quantum systems.
Einj
Hi everybody,
I have the following doubt. We know that for a thermodynamic system the following equality holds:
C_P-C_V=-T\frac{\left[\left(\frac{\partial P}{\partial T}\right)_V\right]^2}{\left(\frac{\partial P}{\partial V}\right)_T}
Now, the mechanical stability of the system requires that the volume decreases with increasing pressure, i.e. (\frac{\partial V}{\partial P})_T&lt;0. So this seems to lead to C_P&gt;C_V. Is that always true? What happen if the temperature is negative, T&lt;0?
Thanks
Science news on Phys.org
The absolute temperature can't be negative, and Cp is always greater than Cv.
chet
I am not really sure about that. There are quantum systems with negative temperature. For example a system with just two energy levels has negative temperature.
I never heard of that, but I don't know much about qm. When I studied qm, I did not encountered the concept of negative absolute temperature.
It depends on the definition. When you work with statistical mechanics the temperature is defined through its relations with entropy, free energy and so on. And it turns out that from this relations it can also be negative.
Yes, but systems with negative temperature are not ever in thermal equilibrium with gasses, and since you're talking about gasses, you are describing an unphysical system.
  • · Replies 23 ·
  • · Replies 23 ·
