Heat equation integral - Fourier Series coefficient is zero
The discussion focuses on solving the heat equation for a thermally insulated metallic bar subjected to two thermal sources at either end, with temperatures of -10 ºC and 10 ºC. The temperature distribution is represented by the equation T(x,t) = u_l(x) + u(x,t), where u_l(x) is the linear steady-state solution and u(x,t) is the transient solution expressed as a Fourier series. The user encounters difficulty in determining the Fourier coefficient b_n, as the integral evaluates to zero due to the temperature function being zero at all points except the boundaries. The correct approach is to expand the transient solution u, not the total temperature T.
  • Understanding of heat equations and boundary conditions
  • Familiarity with Fourier series and coefficients
  • Knowledge of thermal dynamics and temperature distributions
  • Basic calculus for evaluating integrals
  • Study the derivation of Fourier series coefficients in heat equations
  • Learn about boundary value problems in partial differential equations
  • Explore the implications of negative temperatures in thermodynamics
  • Review the application of the heat equation in real-world scenarios
Students and professionals in physics and engineering, particularly those focusing on thermal dynamics, heat transfer analysis, and mathematical modeling of physical systems.
dumbdumNotSmart
WE have a thermally insulated metallic bar (from environment/surroundings) . It has a temperature of 0 ºC. At t=0 two thermal sources are applied at either end, the first being -10 ºC and the second being 10 ºC. Find the equation for the temperature along the bar T(x,t), in function of position and time.
$$ T(x,t)= u_l(x) + u(x,t)$$
$$ u_l = -10+x*20/L $$
$$ u(x,t)=\sum ( a_n cos(kx)+b_n sin(kx) )*e^{-t(kc)^2}$$
So this is a heat equation problem and we have the variables we need. If we consider the extremes of the bar are heated to the thermal sources temperature instantly, then we have #a_n=0# through evalutating T at x=0, t=0. We then evaluate T at x=L, t=0 and so we have ##k=\pi n /L##.
The problem arises when I go looking for ##b_n## because the integral will be equal to zero! According to my knowledge on the subject, to find ##b_n## I have to integrate ##sin(kx)## times the function for temperature at t=0 along x, which is zero at every point except the extremes! Naturally I'd try to convert to Kelvin, but it just doesn't make sense to me that I'd have to do that for it to work, why would a negative temperature break physics for the heat equation?
Edit: I'm almost sure I'm declaring the integral for ##b_n## wrong. I never really understood what the function I was putting inside the integral was when doing heat equation.
No it isn't. You are expanding u in the series - not T.
