guideonl
- Messages
- 58
- Reaction score
- 6
Hi All,
In thermodynamics close system there are two const. processes in which we can calculate the heat:
const. pressure
const. volume
I took 2 simple examples for these processes to test the results according the manufacturer data:
For const. pressure I choose 1 liter 1.5 KW teapot
For const. volume I choose 200 liter 2.5 KW water heater (for shower)
I calculated heats & time in two ways:
For const. pressure I used the data: T1=15 deg C, T2=100 deg C, P=1atm, Cp(avg)=1.875KJ/Kg K, m=1Kg, and the relation q=Cp(T2-T1), thus for 1Kg mass I got Q=159.375KJ. I devided the result by the electric power (1.5KW) and got the time needed to boil the water (1.77 min).
The second way I have calculated was using the 1st thermo. law dq=du (no work), where u2=uf(sat@100degC)=419.06KJ/Kg, & u1~uf(@15degC)=62.98 KJ/Kg assuming the liquid properties could be estimated as the sat prop. @ that temp. Thus, for 1Kg mass I got Q=356.08 KJ. I (again) devided the result by the electric power and got the time needed to boil the water (3.95 min) which makes sense more than the prev. result (about half time shorter).
I did the same calc. procedure for the next example:
For const. volumeI used the data: T1=15 deg C, T2=60 deg C, P=5atm, Cv(avg)=1.42 KJ/Kg K, m=200Kg, and the relation q=Cv(T2-T1), thus for 200Kg mass I got Q=11,360 KJ. I devided the result by the electric power (2.5KW) and got the time needed to heat the water (1.26 hr) makes sense.
The second way I have calculated was using the 1st thermo. law dq=du (no work), where u2~uf(sat@60degC)=251.16KJ/Kg, & u1~uf(@15degC)=62.98 KJ/Kg assuming the liquid properties could be estimated as the sat prop. @ that temp. Thus, for 200Kg mass I got Q=37,636 KJ. I (again) devided the result by the electric power and got the time needed to boil the water (4.18 hr) which does'nt make sense than the prev result.
If I summerize the results:
At const. pressure process, using q=Cp(T2-T1) eq. gives the real and makes sense result.
At const. volume process, using q=(u2-u1) eq. gives the real and better result than q=Cv(T2-T1) eq.
I hope the problems are clear, and I'll be thankfull if somebody will explain why the results are different (when using 1st thermo. law dq=du vs. the process eqs. Cp;Cv(T2-T1)).
const. pressure
const. volume
