Heat Pump Efficiency in Cold Winter Months
Encasing the outdoor condenser of a heat pump may seem beneficial for efficiency in cold winter months, but it risks creating a refrigerator-like environment that could hinder heat absorption. Shielding and insulating the unit could prevent frost buildup, but heating the enclosure would negate the free heat from the environment. Maintaining unobstructed airflow around the condenser is crucial for optimal heat transfer and reducing frost. Using portable electric heaters for localized heating can also be an effective strategy. Ultimately, enclosing the condenser may not provide the expected efficiency gains and could complicate the system's operation.
jpmyob
I've been reading a lot, looking for ways to make my heat pump "work less" or more efficiently in the winter months. Since the HP transfers heat... in the winter it's 'taking' heat from outside and moving it inside.. supposedly heating my house.
Would it be advisable or beneficial (both in out put and energy needed to run the unit) IF I were to encase the outdoor condenser? shielding it and insulating it... Maybe even "heating" the encasement?
If my "outdoor" condenser unit was in "warmer" conditions - wouldn't it have to over come a smaller heating differential between inside and outside? Thus making it run less or more efficiently?
For my real world example- we are in Mid-Tennessee (yes you may all think Tennessee is "south" and therefore warm, but the winters are cold - just not long).. From Nov-Feb we dip into the low 30s F @ night - and Jan/Feb will see Low 20s or teens - Days are usually in the 40s ...
SO. Do I build a shed around my condenser? Insulate it and heat it?
It just seems like having the condenser exposed to the elements is the 'worst' as the temp differential from outside 30F to inside 65F is STILL 35 degrees - it seems the pump is working ALL the time...
Would the shed idea at least help prevent the frost build up? and therefore the "defrost" mode that incurs using the aux heat.?
If you enclose the condenser, it will quickly cool the enclosure to well below ambient.
If you heat the enclosure, then you'll be paying for heat the environment provides you for free.
A few suggestions:
-Make sure the airflow is unobstructed. This improves heat transfer and reduces frost.
-Switch to natural gas on very cold days.
-Spot heat occupied rooms.
thx Russ...
- 1 by airflow - i assume you mean airflow around the outside condenser
- 2 - gas is not an option - I'm rural, and electric is all i have.
- 3 - I don't know what you're driving at with "spot heat occupied rooms".
So if I understand this correctly - it's a closed system... if I enclose the outside 1/2, then it would quickly become a refrigerator (like), and have no heat to grab...
I guess my thought is (and this may be simply a human perception of 'cold' - that 32F is too cold to get heat from...
Thanks again for the reply
No prob...
-Yes, airflow through the heat exchanger in the outside condenser.
-By "spot heat" I mean using a small, portable electric heater to heat just where you are.
-No matter how cold it is outside, the condensing unit coil is going to be colder. It has to be in order for the outside air to heat it up.
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
