Heat Transfer - Conduction/Convection Question - Which area?
Sirsh
Schematic (a) of a slab of conductivity k with uniform heat generation q-dot-o, thickness L, surface temperatures TL and TR, and insulated faces marked by arrows; and diagram (b) of a heated plate immersed in heat transfer oil at 90°C, with a 250 mm by 10 mm plate detail.
Its been assumed that the surfaces TL and TR of the same constant temperature.
Tmax = TL/R + (qdoto*L2)/(8*k)
q = ΔT/R
Rconvection = 1/hA
The problem I am having with this question is conceptualising which dimensions to use (I have no solutions to this question but I am trying to see what is realistic or not).
For part a, I have done the following:
Assuming - L = 0.01m, h = 0.25m and w (depth into page) = unit length of 1.
TL/R = Tsurface = 200°C - ((0.8*106)*(0.01)2)/(8*1) = 190°C
From a thermal network, I know that the temperature difference between the plate and the convective fluid is:
ΔT = Tsurface - Tfluid = 190°C - 90°C = 100°C
Here is my problem, assuming that my associations for the geometry are correct, the convective area (for the thermal resistance equation) should be:
A = p*L + 2*(h*w), where p = perimeter.
Hence, A = 2*(0.25 + 1)*0.01 +2*(0.025*1) = 0.525 m2
And the heat generated, q = V*qdoto = (0.01*0.25*1)*(0.8*106) = 2,000 W
Hence, from the thermal resistance equation qo = ΔT/R = ΔT/(1/hA) ⇒ h = qo / (ΔT*A). h = (2000)/(100*0.525) = 38.1 W/m2K
This seems reasonable for a fluid such as oil, but begs the question whether assuming a unit length into the page is the correct thing to do in this case (where only two dimensions are given)?
Any help would be appreciated!
You were expected to neglect the heat transfer around the perimeter of the element, and include only the heat transfer on the larger faces. Certainly, your first relevant equation does this. Then the length in question would cancel.
Hi Chester, thanks for your reply.
Do you mean that the heat transfer area should only be the two faces that are perpendicular to the heat conduction in Figure a, i.e. what were used to derive the Tmax equation, and not the entire surface area of the box? I'm not sure I follow what you mean.
Yes. That's exactly what I mean.
