Heat transfer equation within soils
2 replies · 4K views · last reply
riscy
I'm seek simple equation that estimate the heat transfer (W/K.m2), conductivity and thermal diffusion rate between cylinder metal rod, about 2 meter length with build in heater of say 10KW and the soil of different type of conductivity and thermal diffusion stated in most textbook.
For example I insert a cylinder rod 10meter within the soil (relative to the surface) and place temperature probe 2 meter from the cylinder, I like a equation to estimate the temperature at the cylinder and the temperature probe and thus validate the actual measurement.
I'm only interested in conduction (ie convection and radiation could be assumed negligible).
The idea is to measure soil performance in removing heat as part of Ground Source Heat Pump pipe networks.
I prefer to avoid complex solution involving vector or such, since withdealing with simple problem, I willing to accept reasonable assumption about the solution.
Please submit comment/paper to riscy00@googlemail.com, no spam please.
Richard Payne
Why? surely there is data on different soil types for engineering applications.
search google for heat conduction of soil...IEEE has data...
There has been a lot of research done on heat extraction from soils by ground source heat pumps. I believe Oklahoma State University has a ground source heat pump research program (or did have). Moisture content of the soil is an important factor. ASHRAE Handbooks would probably be useful as well.
