What factors affect the heating time of a water bottle on a radiator?
  • Context: Undergrad
  • Thread starter Thread starter FelixLudi
    Heating Water
The discussion centers on the factors affecting the heating time of a 0.5 to 0.6 L water bottle placed on a radiator. Key points include that the maximum temperature the bottle can reach is lower than the radiator's temperature due to heat dissipation, and that filling the bottle halfway will not result in a linear decrease in heating time. Instead, less water allows for faster temperature increases due to reduced heat loss and a constant heat input from the radiator. The equilibrium temperature is reached when heat gained equals heat lost, which is influenced by the bottle's surface area and the radiator's heat output.
  • Understanding of heat transfer principles, including conduction, convection, and radiation.
  • Familiarity with thermodynamics concepts, particularly equilibrium temperature.
  • Knowledge of free convection heat transfer equations.
  • Basic understanding of the geometry of cylindrical objects and their thermal properties.
  • Research the equations for free convection heat transfer and radiation heat transfer.
  • Explore the impact of surface area on heat transfer rates in cylindrical objects.
  • Study the principles of thermal equilibrium in heating systems.
  • Investigate the effects of varying water levels on heating efficiency in containers.
This discussion is beneficial for physics enthusiasts, engineers, and anyone interested in optimizing heating processes, particularly in domestic settings involving heat transfer from radiators to liquids.
FelixLudi
Hi,
I didn't know whether or not to put this topic into general physics, classical physics etc. (correct me if I'm wrong on posting here)
Basically I have a normal water bottle, 0.5 L (maybe a little more, up to 0.6 L but definitely not more) and I always heat the water bottle up on a radiator before drinking.
So I have a few questions;
1) Is there a maximum temperature the bottle can reach (not the same as the radiator but lower), before it dissipates more heat rather than it gains?
2) If I fill the water bottle only half way full, will the time required to heat the water up, be exactly half (in regards to heating a full water bottle)?
Considering that the room temperature is average, the bottle is of a cylinder shape (normal shape) with a narrower part at the top, with the water bottle lying only part on top of a radiator (irregularly shaped radiator), and it takes about 1h 30m to heat up the water bottle to "mildly warm" (would call it a solid 30°C (never measured the exact temperature I just drink it when I don't feel it cold in my mouth)).
Disclaimer: This is not a homework question. This is my personal curiosity and interest in opinion and answer from others, as I do not suffice enough knowledge to understand heat dissipation over surface area, heat gain from a source etc.
Note: I will provide any information as it may be required about the question, please do not take this question "jokingly".
Thank you.
Science news on Phys.org
At the beginning, the radiator is putting heat into the bottom of the bottle at a rate proportional to the temperature difference between the radiator and the bottle. As the bottle heats up, the radiator puts less heat into it. If the bottle reached the temperature of the radiator, the radiator would no longer be putting heat into the bottle.
At the beginning, the sides and top of the bottle are either getting heated by the room (if the water is colder than the room) or not losing any heat (if the water is the same temperature as the room). As the water heats up, the sides and top radiate and convect heat into the room. The amount of heat from the bottle into the room increases as the bottle gets warmer.
As the bottle warms, the heat from the radiator into the bottle decreases, while the heat lost from the bottle increases. At some point, the heat added equals the heat lost. At that point, the bottle temperature is stable. It will be less than the radiator temperature (because heat is still going from radiator to bottle) and warmer than the room (because it is losing heat to the room).
Less water in the bottle means it will increase temperature faster because the radiator is putting the same amount of heat into less water.
I agree.
But is the principle of having half a bottle being heated up proportional to having it heat up exactly twice as fast, or will it heat up more than twice as fast because it has less surface area to heat up and it will radiate more but the heater's surface area to the bottle is the same, so it will just add heat more than it loses?
Take a look at the equations for free convection heat transfer and radiation heat transfer (Google those terms), along with the assumptions involved. Myself, I'll go along with about twice as fast, but not exactly twice as fast.
  • · Replies 66 ·
  • · Replies 27 ·
  • · Replies 28 ·
10K
