Height for 1/100 normal weight above Earth's surface
26 replies · 4K views
Stratosphere
How high above the surface of the Earth should a rocket be
in order to have 1/100 of its normal weight? Express your answer
in units of Earth radii.
Im not sure were to start with this one. I know that the moon is 60 times as far away as the core of Earth to the surface.
Use the gravitational force equation
[tex]F = G\frac{Mm}{r^2}[/tex]
and
F = mg
Setting the two equations equal to each other provides the acceleration due to gravity as a function of the distance, r, from the center of the earth.
You'll need this formula
[tex]F=\frac{GMm}{r^2}[/tex]
Where M is the mass of the Earth and m is the mass of the object.
how do you get G or calculate the mass of the earth?And which one of you is right? Yor saying two diffrent things.
Mass of the Earth and G are found in any physics book; usually in an appendix.
i found the mass of Earth 5.9742*10to the 24 power and the radius but how do i know the mass of the rocket? Or G?
The mass of the rocket, m, is not required. When setting F = mg equal to the gravitational force equation the m on each side cancels.
G is the universal gravitational constant. You should be able to find the value in the physics book or on line easily.
You already have the answers you need, G is a well known physical constant, get it from a textbook or find it online. And as for the mass of the rocket, equate the equations given by chrisk and you will discover why it is irrelevent.
1 6.67300 × 10-11 m3 kg-1 s-2 i hope i made it look right. So what do i put in for Kg and s and m?
The appropiate units will cancel. Make sure the units for the Earth radius is in meters.
i got 24485606.14 that's not right is it?
I have not done the calculation but express the value in Earth radii then subtract one Earth radius from this value to give the height above the Earth surface.
What i did to get G is 6.67300 × 10-11
i got 383.9 kilometers above earth.
Thats not right, and you still haven't expressed it in units of Earth radii.
i looked up the real answer from a website and it said the answer is 57,402 and 9 Earth unit radii.
That is the correct answer, if you still don't understand try posting your workings and I'll show you where you have gone wrong.
first i did F= G*M/r2
M=5.9742*1024
R=6378.1
G=6.67300 × 10-11
What did i mess up?
after equating the two force equations you should have been left with:
g=G*M/r^2
you need to rearrange this for r and solve it
What do you mean equating the two force equations?
and
F = mg
those are the force equations!
equating:
F = F
LaTeX Code: mg = G\\frac{Mm}{r^2}
oops that didnt work, I mean:
F = F
mg = GMm/[r][/2]
