- 42,807
- 10,496
Next, what is the pressure inside tube d at A? Look at what connects this to B.
The height of a Heron's fountain is influenced primarily by the pressure in "bottle b," which is determined by the hydrostatic pressure of the water in the system. Key variables affecting this pressure include the volume of liquid (V), the density of the liquid (ρ), and the height difference (Δh) between the water levels in the connected bottles. The relevant heights to consider are the top of the tube (tube d), the top surface of the water, and the bottom of the container (bottle c). Understanding these relationships allows for accurate predictions of fountain height based on the principles of fluid dynamics.
PREREQUISITESStudents studying physics, engineers designing fluid systems, and hobbyists interested in constructing hydraulic devices will benefit from this discussion.
Is the pressure inside the tube d at A more or less than the pressure at B?Dami121 said:The tube is full of water, so I think the pressure in tube d at A would be
P = h1ρg+h3ρg ?
Not sure what you mean.Dami121 said:the initial pressure from the air in bottle B remains the same in the whole liquid no?
To be clear, the way you are using h1 ... h3 they are depths from the top, not heights from the bottom. So you mean that the depth at A is less than the depth at B.Dami121 said:the height A is smaller than height B
Yes.Dami121 said:the pressure in the tube d at A must be smaller than at B.
Yes.Dami121 said:pressure at A in the tube would be:
P = h3ρg-(h2-h1)ρg
Try that step again.Dami121 said:h3ρg-(h2-h1)ρg - h1ρg = (h3-h2-2h1)ρg??
Yes.Dami121 said:Oh, stupid mistake,
ΔP=(h3-h2)ρg
Is that it?
First thing is to understand how the pressures in the different airspaces are related.Physicist1011 said:No I don't. I don't understand how the differences in heights of the water affect the water height and I also don't understand how you got that equation.
If they were different, what would the air do?Physicist1011 said:The pressures are the same? but why?
Right.Physicist1011 said:Move towards lower air pressure.
If two reservoirs are connected by a filled pipe they are effectively a single reservoir. What relates the pressures at two points in a reservoir?Physicist1011 said:I am not sure.
Consider a tank of water. How does the pressure at height y1 from the bottom relate to the pressure at height y2 from the bottom?Physicist1011 said:Sorry I am really not sure as this is what I am confused about.
How does the pressure at d relate to the difference in heights since the pressure is what relates to the fountain's height right?
Yes, but by how much?Physicist1011 said:These 2 heights of water are connected in a closed space (except for the water surface at the top). Such that the pressure of the lower height will be larger than that of the higher water height.
Right.Physicist1011 said:Pressure difference = pgh2(higher water height) - pgh1(lower water height)
Edit: oh so change in pressure from upper height to lower height = change in height *pg
Is there a path between those two surfaces that is entirely in water?Physicist1011 said:Pressure difference between B and A = pg*height difference between water surface B and A
I am not seeing it.Physicist1011 said:Yes there is.. that's why there is a pressure difference.
