Heisenberg and quantum mechanics
74 replies · 9K views
moving finger said:
You're not measuring position and momentum simultaneously in your experiment, you are measuring them sequentially, via two separate measurements (the "slit" measures position, and a certain time later your CCD detector measures another position, from which you infer a momentum). But you can only correctly infer momentum from this second measurement if you assume that the electron has behaved like a classical macroscopic object between the two measurements. The measurements are separated in time, thus not simultaneous. Check any good text on QM, they all say the same thing - one cannot measure position and momentum simultaneously to arbitrary precision.
Best Regards
I don't understand this "measuring position and momentum simultaneously" stuff. You will note that the very fact that non-commuting operators, by definition, do not commute, means there is an ORDER in the measurement of the observables. You get one result when you measure A first, and then B, versus measuring B first, and then A. Where is this "simultaneous" measurement? Since when does the HUP requires such a thing? As long as the system remains isolated and does not lose coherence, the HUP kicks in. In the example I mentioned, there is no "simultaneous" measurement, yet you STILL have a demonstration of the HUP.
Can you point to me a "simultaneous" measurement that demonstrates the HUP? If you say one cannot make such a measurement, then you are implying that the HUP doesn't exist.
and take note that the original argument I was trying to correct was the fallacy surrounding the accuracy of a SINGLE measurement of position and a SINGLE measurement of momentum of a SINGLE particle. The accuracy of a single measurement of observable A and B are NOT goverened by the HUP. Have we settled this yet before migrating to this "simultaneous" issue?Zz.
MeJennifer said:
But if you measure the position of a particle, don't you disturb the momentum of particle? So that when you shortly after this measure the momentum, you would have to take into account the amount of disturbance the initial measurement gave. And since we don't know that we can only use statistics?
There's two kinds of "disturbance". One is spurious intrusion, the other is inherent. Spurious intrusion is when an electron, let's say, passes though a slit and it sees its own image and causes a self-interaction. This is NOT taken into account in the ideal situation and is not what we are talking about. What we are dealing here is the inherent effect that is built in into our physics (and our universe).
So what kind of a disturbance would there be when photons passed through a single slit? Note that in such a case, all you are doing is to cause only photons that happen to pass within the opening to get through. So even when you ignore all the other spurious intrusions, by simply confining the x-position of the photons to such a narrow size already can cause a change in the expected momentum of the outgoing photons.
So OF COURSE, there is an effect due to the slit. The very fact that there is now a transverse component of the particle where there wasn't any before is obvious. But this is right out of the HUP and the QM formulation.
Zz.
Well as long as the particle does not bounce against the wall it seems that there would be no disturbance. But of course a particle is more than just an object at a specific location, it also can carry and interact with forces from other particles.
I suppose that it can interact with forces from other particles (e.g. the endges of the slit) even when its position is not at the edge.
But is this particle-particle interaction built in in the HUP and QM formulation?
We know what particle-particle interaction entails - I do this as a condensed matter physicist. But turn it off and you STILL get the HUP. We can see this already since there's nothing to prevent us at sending each of these particles through the slit one at a time. There's no particle-particle interactions here.
Zz.
Has anyone produced a model of the "non-Heisenberg" interactions between a particle and the edge of a slit that it passes through, that accurately describes diffraction phenomena that have been observed? I've never seen or heard of such a model. If such a model existed, and were widely accepted, it would surely be mentioned in many textbooks when particle diffraction is introduced.
MeJennifer said:
I really don't see how this EPR experiments disproves experimental uncertainty. How do we know for sure that even after the two particles are separated there is not some connection between them?
Well, there is, sort of - they are part in superposition of the same wave function. But are they mediated by a physical non-local force? That is certainly a possibility that cannot be absolutely ruled out. If you accept Bohmian Mechanics, then that is indeed the case... and now the HUP can be explained in different terms. I would say that many scientists do postulate that there is some sort of non-local physical mechanism (for lack of a better term) involved. But I would not say it is generally accepted as such.
lalbatros said:
That's right the uncertainty principle doesn't allow you much predictions.
It is merely the root of quantum mechanics.
Further, it explains the most fundamental predictions.
Like the [blah blah blah]
... any more ?
Let's start a big list ...
Michel
Congratulations on misrepresenting what I wrote, confusing what the "root" of quantum mechanics is, and - best of all - missing the forest for the trees.
I'll say again: The uncertainty principle is not the primary barrier in "predicting everything," as the opening post suggests. On the contrary, we're more than capable of predicting many things even beyond the necessary precision and accuracy necessary, and yet are completely stumped at predicting other things (weather, turbulent fluid flow, economic shifts) within an order of magnitude of the precision we would prefer.
Well to me it seems that all forces work non-local.
Locality seems only relevant when there is some sort of scattering, which I see as a space-time event where two (or more) particles happens to interact. The other forces kind of "hover" above space-time directing the probability of the location of the particle.
OK, could you point out to me an example of a "non-local" EM force at work?
Zz.
I would say pretty much every force that require some sort of wave function. :smile:
Could you point out to me an example of a force that is local?
superweirdo said:
What I want to know is how? How did he show it coz that conters my belief of predictability. I believed that w/ infinite knowledge and tools, we could see the future coz we would have the ability to predict everything.
So what situation does the HUP actually prevent us from predicting something? The most obvious (and probably only) situation is one that fits the following criteria:
1) The prediction involves a system exhibiting quantum mechanical phenomena. More precisely, the system must require quantum mechanics to make predictions. I've had individuals in this forum try to argue that large objects (such as tennis balls) must be described as a wavefunction, but anyone with sense or a grasp of physics knows that most massive objects shouldn't be - at least if you plan to actually predict what will happen in the system.
2) The prediction involves taking two consecutive measurements whose operators don't commute. The HUP only affects something multiple consecutive measurments that are in some special way related. The addage about position and momentum isn't even entirely accurate: for instance, you can know the position in one direction and the momentum in an orthogonal one without violating the HUP at all.
3) The prediciton must require precision for multiple noncommuting measurables that is less than the HUP would allow. This alone removes just about any measurement ever made to predict some result. We don't need precision that low for most military, economic, physical or social issues that we would like to predict. The universe is one of many scales, and almost none require us to measure things to that small a degree.
It should be plainly obvious that the HUP doesn't prevent us from predicting what will happen in any but a select set of arenas.
You'll notice that I made no assertion one way or the other. You did. And your answer is very vague. Show me exactly one concrete example which clearly illustrates what you mean by a force that is "non-local".
Zz.
Zz.
Well EM waves in the EPR experiment for instance.
*snip*
In fact, the uncertainty principle allows us insight and predictions into fundamental questions which were proposed at the beginning of the 20th century - like why electrons are not found in atomic nuclei.
I think it was from Beiser's Modern Physics, he stated that the HUP was not a limitation of our knowledge, but a useful tool unto itself.
Er... what EM waves? The EPR experiment in which there is entanglement has no transfer of any kind of interaction when a measurement on one of the pair is made! There's no EM wave, no "strong" wave, no "weak" wave, no gravity wave of any kind going from one to another. Even the QM description shows no kind of EM "wave".
So how did EM wave became non-local here? You do know that the QM wavefunction is not the same as the EM wave, don't you?
Zz.
Perhaps you should have said so earlier, when it was first mentioned in post #8, which you responded to but obviously ignored the reference to “simultaneously”.
See the following for a paper on the Simultaneous Measurement of Noncommuting Observables :
http://prola.aps.org/abstract/PR/v152/i4/p1103_1
It has never been claimed that the HUP “requires” such a thing – but the HUP places limits on the precision with which such simultaneous measurements can be made.
The HUP applies all the way through, it does not mysteriously “kick in” just when you are about to make another measurement.
I have never said that a simultaneous measurement “demonstrates the HUP”, and I have never said that such measurements are impossible – you seem to misunderstand.
I understand that you believe the OP was referring to sequential measurements – and I have no problem agreeing that two sequential measurements can provide you with information as precise as you would like – but I do not believe such was the intent of the OP.
Best regards
Best regards
This is the OP:
superweirdo said:
Heisenberg showed that, even in theory with a hypothetical infinitely precise instrument, no measurement could be made to arbitrary accuracy of both the position and the momentum of a physical object.
And this was your response to me in post #8
moving finger said:
To be fair to superweirdo, what he should have said is “we cannot simultaneously know to arbitrary precision both the position and the momentum”
Best Regards
I "ignored" the "simultaneous" aspect of it because QM and the HUP never require such a constrained in the first place. So I do not see the point of discussing a "special case" when the GENERAL case is equally valid. I don't have to make a "simultaneous" measurement of the non-commuting observable to detect the HUP. In other word, I don't have to go through all that difficult contortions to detect this. An ordinary one, such as from a single slit, will do just fine. This is why I said I do not understand why such a thing needs to be brought up in first place.
Secondly, recall what I am trying to do here. There is a very common fallacy that one cannot determine (be it simultaneous or not) the position and momentum with arbitrary precision of a particle. This is wrong. The HUP never says such a thing. The single measurement of a position is limited in accuracy only by the instrument. The same can be said of the position. The HUP is not about the value of p and x after a single measurement of each, but rather the spread in p and x and consequently, our ability to predict their values. This applies be it a simultaneous or non-simultaneous measurement.
And oh, aren't you curious that in the paper you cited, their definition of a "simultaneous" measurement is actually the same as my single-slit example? See Fig. 1.
Zz.
Zz.
So photons are not EM waves?
The EM waves are NOT the "wavefunction" of QM. You don't solve the Schrödinger equation for photons and get EM waves that you get out of Maxwell equations as the solution.
So again, where is the non-local interaction of EM?
Zz.
Zz.
Where did I say that the EM waves and the wave fuction are the same? :confused:
You were asking me about forces, electro-magnetism is a force.
And you were claiming that EM forces are non-local. The "non-local" connection cannot be made using classical EM theory. And since you invoked the EPR experiment, then it must be quantum mechanical. But in such an experiment, no EM interactions is invoked upon measurement. QM entanglement may imply non-locality, but NOT EM interactions. No EPR papers that I've read have ever made such claims (and neither has QED)
You are being VERY terse in explaining yourself after each of my question. If this is how you wish to proceed with each of your claim, then I suggest you do not make such claims in the future since you appear to refuse to elaborate in detail, but rather make a specific citation of the paper that can back your claim. So in this case, please point out to me the EPR paper/s that have explicitly made the claim that the results imply a non-local EM force.
Zz.
Are you suggesting that photons are not EM interactions?
Well I thought we had a friendly discussion about this. We don't have to discuss it, really. Sorry then!
One could clearly interpret the results of EPR as a non-local interaction which I do. This is not new at all. You may disagree but I don't understand what your problem is with me stating that.
Locrian,
By Locrian Congratulations on misrepresenting what I wrote ...
I did not try to represent your saying, I quoted them in full !
But english is not my native languange, maybe I misunderstood what you said (specially the word hurdle).
Now, let me note that what you quoted by "BlahBlah ..." from my post is what I consider the most interresting for a discussion: examples of how the HUP can make us understand the essentials of a quantum effect. Maybe not a hurdle ...
Michel
Absolutely.
I don't think Zapper is disagreeing that entangled EPR pairs can imply nonlocality; he is only objecting to ascribing that nonlocality to the EM forces. (I would agree with that.)
Edit: I didn't intend to imply that Zapper was agreeing or disagreeing about whether EPR implies nonlocality, just that whatever is going on, no one is claiming that there exist nonlocal electromagnetic forces.
DocAl said:
Absolutely.
I don't think the quantum correlation between the entangled particles can be described as an "interaction", much less a "force". For that matter "nonlocal" is a subject of much contention, on this forum and elsewhere. Experienced professional physicsts cannot all agree.
There's nothing wrong with "discussion". However, I don't consider terse, one-sentence responses as "discussion". Furthermore, if you have reviewed our guidelines, we clearly prohibit speculative discussion. Since "non-local forces" as derived out of EPR experiments are what I consider to be speculative (i.e. no EPR papers have ever concluded forces are non-local), it was why I asked to elaborate further since I do not understand your claim. This, you have refused to do.
You need to first understand how "entanglement" of a particular observable correlates to "non-locality". The problem you had was that you are assuming that just because that observable exhibit non-locality, then there MUST be a force that is transmitted that is non-local. There's nothing in QM that implies such a thing. There are no "non local interaction" here since there's nothing that "interacts". Look closely at ALL the EPR experimental paper if you don't believe me. You will notice that not one of them indicates that "forces" are non-local. So it is your interpretation of the results that is faulty here.
Try this one. I have an object A that is stationary, and has no angular momentum. At some time, it explodes into 2 separate pieces that fly off in opposite directions. At a later time, I capture one of the pieces and found out that it has an angular momentum L1. Immediately I know exactly the angular momentum of the other piece L2.
There's nothing quantum mechanical here. In fact, it is purely classical. Are you telling me that in this case, there is a "non-local" force that went from one of the pieces to the other? Everything after the instant of measurement here is identical to the EPR/QM experiment.
Zz.
Agreed. That's why *I* didn't make any assertion of something being local or non-local. However, to claim that EM forces are non-local based on the EPR experiment is erroneous. Even if the entanglement is non-local, there's nothing here that implies that it is due to EM interactions. MeJeniffer has made a faulty connection between two separate phenomena.
Zz.
I did not say that and that is not my position at all.
My interpretation is that there is communication at a distance as soon as a measurement is made on one part of the entangled setup. That is just a particular interpretation, and I am certainly not the only person in the universe who makes that interpretation. Are you suggesting that this is any more "speculative" than other interpretations? If so, feel free to demonstrate that. :smile:
I think you misunderstand the forces part. For instance if we make a correlation on photon observables we are dealing with electro-magnetic forces correct? Or are you suggesting that a photon as a particle has unique properties that are not related to electro-magnetism?
Well in my interpretation, at the quantum level, we don't deal with objects at all. It s not "Newtonian" mechanics, and trying to make it look like that will obviously give "paradoxes".
In EPR we make a statistical correlation of the measurements of different observables. The superposition "knows" the result of the first measurement.
However there is no "force" involved as you suggest I claim. I do not claim that at all. But the complete quantum state is spread out over space, it is therefore non-local.
"communication" at a distance is FAR from being able to be connected to "forces". You have made that connection between the entanglement of observables with "forces". Somehow, you continue to ignore this connection that isn't made in all the EPR papers. That is why I continue to ask you to show this explicit connection.
I think you misunderstand the forces part. For instance if we make a correlation on photon observables we are dealing with electro-magnetic forces correct? Or are you suggesting that a proton as a particle has unique properties that are not related to electro-magnetism?
No, I measure an observable. The fact it happens to be the polarization of a photon is irrelevant. I could easily measure the momentum of a neutrino if I can make that observable in that system be strongly entangled. So then what? What's the "force" you are dealing with here?
Look again at the description of an entangled system. WHERE is the "force" mediating between the entangled particles?
Well in my interpretation at the quantum level we don't deal with objects at all. The is not "Newtonian" mechanics.
However there is no "force" involved as you suggest I claim. I do not claim that at all. But the complete quantum state is spread out over space, in it therefore non-local.
Then why in hell did you say these?
So you now claim that I am the one who suggested this? You made an explicit connection that there are "EM waves" in EPR experiment, and now you are saying that there's no such forces in such a scenario?
Oy vey.
Zz.
It simply seems that we have a fundamentally different interpretation about what those elementary particles are.
To me they are waves, they are not little "balls".
So to explain paths by some sort of Newtonian mechanics does not make sense, and it actually does not work.
Look at momentum, can anybody with a straight face explain to me how a particle could have a momentum that is an imaginary number in space-time? Or a fractional spin?
I think a wave interpretation makes more sense, waves that spread out over time and operate non-locally.
