Help ~ Calculate the maximum noise voltage
1 reply · 3K views
poon2009
Help!~ Calculate the maximum noise voltage
Two conductors, each 10-cm long and space 1-cm apart, form a circuit.
This circuit is located where there is a 10-gauss magnetic field at 60 Hz.
What is the maximum noise voltage coupled into the circuit from the
magnetic field?
From this book--Electromagnetic compatibility engineering- Chapter 2
http://books.google.com.hk/books?id...resnum=4&ved=0CDkQ6AEwAw#v=onepage&q&f=false"
377uV
Does anyone could teach me how to calculate it?
Thank you!
magnetic field?
377uV
Thank you!
The link does not appear to be translating...
In any case, what is the equation that you use to calculate the induced voltage around a wire loop from a changing magnetic field? That's what you should use here...
