arpace
- 9
So I have a Hermite curve with the control points:
//point# (x,y):
p0 (1,0)
p1 (1,(Math.sqrt(2)-1))
p2 (Math.sqrt(0.5), Math.sqrt(0.5))
I also have a very basic algorithm to find the point on the locus at a given degree between 0 and 45 degrees using the control points. I could extend it easily to 360, but I will wait to do so until I figure out what is going on.
AS3
Javascript
if you run the code, you will see why I am having problems.
What is going on? I am assuming I overlooked something. I thought it might be due to floating point error, but although there is some rounding error, it doesn't seem to be the issue.
Below is an image I made to help myself with the concept.
[PLAIN]http://sphotos.ak.fbcdn.net/hphotos-ak-snc4/hs1384.snc4/163638_10100121877154282_28122817_59279302_5323393_n.jpg
//point# (x,y):
p0 (1,0)
AS3
Code:
//modify the degree
var degree:Number = 22.5;//modify this
function yAtAngle0to45(deg:Number):Number {
if (deg < 0 || deg > 45) {
trace('please keep it between 0 and 45 for now');
return -2;//if -2 is returned, you know it is out of possible bounds
obviously if this was in a real math class,
p1y would be stored outside the function and
there would be error checking/handling code
var p1Y:Number = Math.SQRT2 - 1;
var degDivBy45:Number = deg / 45;
var line0Y:Number =(p1Y)*degDivBy45;//point on line 0
var line1Y:Number = p1Y + (Math.SQRT1_2 - p1Y)*degDivBy45;//point on line 1
return (line0Y + (line1Y-line0Y)*degDivBy45);
trace( "my code: " + yAtAngle0to45(degree) + "\nstandard: " + Math.sin(degree*Math.PI/180));
Javascript
Code:
//modify the degree
var degree = 4;//modify this
function yAtAngle0to45(deg){
if (typeof deg != 'number') {
return Number.NaN;
var p1Y = Math.SQRT2 - 1;
var degDivBy45 = deg / 45;
var line0Y=(p1Y)*degDivBy45;//point on line 0
var line1Y = p1Y + (Math.SQRT1_2 - p1Y)*degDivBy45;//point on line 1
alert( "my code: " + yAtAngle0to45(degree) + "\nstandard: " + Math.sin(degree*Math.PI/180));
