Help Linear Algebra transformations, is my understanding correct?
2 replies · 3K views
degs2k4
Hello,
I would like to check if my understanding of this linear algebra problem dealing with transformations is correct:
Part (1)
we have the following coordinates systems:
[tex]\tilde{x} = \begin{pmatrix} x_1 \\ x_2 \\ 1 \end{pmatrix}[/tex] and [tex]x = \begin{pmatrix} x_1 \\ x_2 \end{pmatrix}[/tex]
and the following equation : [tex]\tilde{x}^T \tilde{A} \tilde{x} = 0[/tex]
This parts only asks for getting the A matrix (symmetric matrix with coefficients) from a quadratic curve. Taking a look at the final parts of the problem, I guess this part is some sort of coordinates change from [tex]\tilde{x} \rightarrow x[/tex] using a matrix A, is this right? (like some sort of 3D-2D transformation) Part (2)
[tex]x = \begin{pmatrix} x_1 \\ x_2 \end{pmatrix}[/tex] and [tex]y = \begin{pmatrix} y_1 \\ y_2 \end{pmatrix}[/tex]
and the following equation : [tex]x = Py[/tex]
My thoughts: The equation in (i) corresponds to a quadratic curve, which has been rotated (it has a cross product term) and translated (it has terms y1^2, y1). In this part we want to transform (i) into (ii). In this transformation we undo the rotation (by rotating) and the matrix used is for it is P, transforming x coords into y coords.
Part (3)
[tex]y = \begin{pmatrix} y_1 \\ y_2 \end{pmatrix}[/tex] and [tex]z = \begin{pmatrix} z_1 \\ z_2 \end{pmatrix}[/tex]
My thoughts: The equation in (ii) corresponds to a quadratic curve, which has been translated (it only has terms y1^2, y1). In this part we want to transform (ii) into (iii). In this transformation we undo the translation (by translating), with an equation like this:
[tex]z = y + M[/tex]
transforming coords y into coords z. Part (4.A)
[tex]z = \begin{pmatrix} z_1 \\ z_2 \end{pmatrix}[/tex] and [tex]\tilde{z} = \begin{pmatrix} z_1 \\ z_2 \\ 1 \end{pmatrix}[/tex]
and the following equation : [tex]\tilde{z}^T \tilde{B} \tilde{z} = 0[/tex]
This parts looks like part 1, getting the matrix from a quadratic curve. Taking a look at the rest of the parts of the problem, I guess this part is a coordinates change from [tex]z \rightarrow \tilde{z}[/tex] using a matrix B, is this right? Part (4.B)
[tex]\tilde{z} = \begin{pmatrix} z_1 \\ z_2 \\ 1 \end{pmatrix}[/tex] and [tex]\tilde{x} = \begin{pmatrix} x_1 \\ x_2 \\ 1 \end{pmatrix}[/tex]
and the following equation : [tex]\tilde{x} = \tilde{Q} \tilde{z}[/tex]
This part is the composite transformation from (i), using coords [tex]\tilde{x}[/tex] to (iii) using coords [tex]\tilde{z}[/tex]. So composing all transformations from the previous parts into one, my guess is that :
[tex]\tilde{Q} = ((\tilde{A} P) + M)\tilde{B}[/tex]
would this be ok?
Thanks in advance and sorry for the long post...
degs2k4 said:
Hello,
Part (1)
You want
[tex]\begin{bmatrix}x_1 & x_2 & 1\end{bmatrix}\begin{bmatrix}a & b & c \\ d & e & f \\ g & h & i\end{bmatrix}\begin{bmatrix}x_1 \\ x_2 \\ 1\end{bmatrix}= x_1^2+ x_2^2- 6x_1x_2+ 2x_1+ 4x_2+ \frac{15}{9}[/tex]
That gives you a number of equations for a, b, c, d, e, f, g, h, and i.
Part (2)
Part (3)
Part (4.A)
Part (4.B)
would this be ok?
HallsofIvy said:
You want
Thanks for your reply!
Yes... I already got the values for a-i. What are you trying to say ?
