Right endpoint formula giving wrong area for f(x)=4-x² on [1,2]
  • Thread starter Thread starter kingkong11
    Curve
6 replies · 2K views
kingkong11
I need to use the right endpoint formula to find the area under the curve f(x) = 4-x2 over the interval [1,2]
I integrated this problem and got 5/3. But doing it the long way got me 11/3. Can someone where I made my mistake on applying the right endpoint formula, thanks!
right endpoint formula = [tex]f(\frac{b-a}{n}*k)[/tex] and [tex] \sum_{k=1}^n K^2 = \frac{n(n+1)(2n+1)}{6}[/tex]
Before I use the right endpoint formula I tried integration and got:
[tex]\int_{1}^{2} 4-x^2 dx = \left[ 4x-\frac{x^3}{3}\right]_{1}^{2} = \frac{5}{3}[/tex]
here is what I got using the right endpoint formula:
[tex]\lim_{n\rightarrow\infty} \sum_{k=1}^n f(\frac{k}{n})*\frac{1}{n}<br /> = \left[4-(\frac{k^2}{n^2})\right]*\frac{1}{n}[/tex]
[tex]= \frac{4}{n} - \frac{K^2}{n^3}[/tex]
[tex]\lim_{n\rightarrow\infty} 4 - \frac{1}{n^3}(\frac{(n(n+1)(2n+1)}{6} )[/tex]
[tex]= 4 - \frac{1}{3} = \frac{11}{3}[/tex]
You made a mistake using the right endpoint, mainly the set up of the problem the way I see it.
It should be something like:
lim as n --> infinity
summation from k = 1 to n of
[4 - (1 + k(1/n))^2] x (1/n)
I looked at my setup again, but I still don't see the mistake. Where did you get the 1 from? [4 - (1 + k(1/n))^2] can you explain a little more please?
Thanks
Thanks
what you substitute for x should be in the form a + k(delta x) since it's a right endpoint approximation (at least the way I learned it). where a is the lower bound of integration or first number in the interval, in this case 1.
Edit: I get 5/3 my way.
Yea, the formula I used is off that's why I was not able to figure out which part I made a mistake on.
While on the subject of formula, do I switch formula when I have an increasing function?
What do you mean?
The formula depends on where you are approximating, i.e. right endpoint, left endpoint or midpoint.
