Expert Tips for Solving Indefinite Integral for Arc Length of f(x) = 3x^2
  • Thread starter Thread starter Phys_Boi
    Integrate
The discussion centers on solving the indefinite integral for the arc length of the function f(x) = 3x^2, specifically L = ∫ √(1 + 36x^2) dx. Participants highlight the importance of using the correct integral and suggest that the original poster may benefit from reviewing arc-length formulas. Trigonometric and hyperbolic substitutions are mentioned as potential methods for solving the integral, with emphasis on understanding the underlying concepts rather than relying solely on computational tools. The conversation also touches on the educational aspect of learning integration techniques and the value of visualizing problems through diagrams. Overall, the thread emphasizes the need for a solid grasp of integration fundamentals to tackle such problems effectively.
Phys_Boi
So while doing arc length integrals I can't figure out how to solve them. For instance:
f(x) = 3x^2
f'(x) = 6x
So.. the length, L = ∫ √(1+36x^2) dx
How do you solve this indefinite integral?
Notice: I know you can solve this easily with bounds by approximation but how do you solve it indefinitely
Thank you
[/B]
f(x) = 3x^2
f'(x) = 6x
So.. the length, L = ∫ √(1+6x) dx
Notice: I know you can solve this easily with bounds but how do you solve it indefinitely
Thank you
[/B]
Can you show how you would solve it with bounds?
f(x) = 3x^2
f'(x) = 6x
Thank you
[/B]
If you say you can solve it easily with bounds, why can't you solve it without bounds? Usually we get the "bounds" result by substituting the bounds into the "no-bounds" result!
Anyway, arc-length problems should have bounds, since you usually want the arc length between two points ##(x_1,y_1)## and ##(x_2,y_2)## on the curve.
Finally: you have the wrong integral. Go back and check the arc-length formulas in your textbook or course notes (or in on-line sources).
Likes berkeman
I would just type it into the good ol calculator or wolfram. And you're right, I just didn't square it. But I don't know how to solve it without approximation
If you rely on tools like Wolfram to do elementary integrations for you, then you cannot possibly learn the subject. That sounds to me like a recipe for failure.
f(x) = 3x^2
f'(x) = 6x
Two words that I hope will ring a bell: trig substitution
Well thank you for responding, but I am a junior in high school and am currently taking Ap Calculus (CALC 1) and have not yet covered integrals/antiderivatives. However, I love math (the reason I'm a year ahead everyone else in math) and I just don't know how to take this integral. I do know how to take others though and also the applications.
Thank you sir.
First thing to do is to get the right function to integrate, see #3.
If that too is a mystery how to integrate, draw a picture of what it is on a circle, you're doing an exercise like this I think you must know the equation of a circle, and the integral will be almost obvious.
And if you prefer to do it by substitution, or to do that as a check and exercise which is not a bad idea, you will see why anyone would hit on that particular substitution, instead of it being in the being told and 'I would never have thought of that' category.
Then it's not finished!
Do not leave an integral like that without differentiating it as a check. This will save you making a lot of errors, and should bring you some enlightenment in this case.
Then it's still not finished! Do not miss this occasion to check up how to do the integral of the function that you mistakenly gave, and which is closely related to the correct one. Because doing all this will be giving you an insight and empowerment over this little area of some integrals quite important in geometry and Physics (and even chemistry some of them).
Edit: on second thoughts having read now where you are, that last bit might involve too many things you have not done yet, but you are quite close to, so have a look and if it's too much dear it in mind for the future.
Good luck. Don't omit to come back when you have the answer or are stuck again.
Thank you sir.
The suggested trig substitution will not work well; you need hyperbolic functions rather than trigonometric functions for this problem.
How so?
The integral in post #1 was ##\int \sqrt{1 + 6x}dx##, but was later edited by the OP to ##\int \sqrt{1 + 36x^2}dx##. After a suitable trig substitution, you end up with ##\int \sec^3(\theta) d\theta##, which can be integrated using int. by parts or by looking it up in a table of integrals.
Mark44 said:
How so?
I was thinking of the substitution ##x = (1/6)\sinh(y)##.
I come back to clear up confusion I may have caused the OP. I have been a bit thrown off by the comments that he had the wrong integral - it is in fact OK isn't it? Anyway I had been led to consider the integral ∫√(1 - x2) dx. This too was not self evident to me at first glance.
And then I was exercised by Ray's comment
. I wonder rather if that is not something that in the next decades will go the way of not being allowed to use calculators. My experience at least was that you can get pretty skilled at this at school, and within a year you'll have totally forgotten it.
In any case it ought to be made as easy as possible. So taking a look at the integral I quote above I realized that you can make it quite obvious by a diagram. And I have noticed this before with some other integrals that turn out to be 'trigonometrical'. But I was not told this at school, it is not in the books I have nor any I have seen.
Asked the above integral you can justify the book method by saying 'look for some function that squared and subtracted from one is a perfect square so then you're not bugged by the square root'. The majority of us however would not get that without being told, or at least nudged. But, yes, trigonometrical functions, sine or cosine have that property. Still it depends rather on hindsight or familiarity. I think a graph that makes it obvious is better.
Then for the integral ∫√(1 + x2) dx the hyperbolic functions have the property required in the previous paragraph when we say 'add to' instead of 'subtract from'. Diagrammatically I am not seeing it yet, due to the hyperbola being a lot less familiar than the circle. Am working on that and other approaches.
I was however assuming the OP was not familiar with the hyperbolic functions. Actually this second integral can be done by a trigonometrical substitution:
x = tan u. You do not need explicitly hyperbolic functions, there are other forms. It is not exactly a doddle however.
  • · Replies 44 ·
