Help me solving a Derivation equation
  • Thread starter Thread starter ishahad
    Derivation
5 replies · 1K views
ishahad
find the derivative of the given function:
f(x)= 6 - (1/x) / x-2
the solution on the answer key is (-6x^2 + 2x - 2 ) / (x^2 (x-2)^2)
i don't know how to solve it :(
Welcome to PF;
Lets just check that I understand you:
You are given $$f(x)=\frac{6-\frac{1}{x}}{x-2}$$... and you are asked to find $$f^\prime (x)=\cdots$$
It looks awkward - have you tried expressing the fraction in a simpler form?
There is a rule for differentiations where f(x) takes the form: $$f(x)=\frac{g(x)}{h(x)}$$ ... do you know what that is?
Assuming that Simon correctly interpreted what your function should have actually been, you needed to include sufficient parentheses .
f(x) = (6 - (1/x) ) / (x-2)
You have written
[tex]f(x) = 6 - \frac{1}{x x} - 2 = 4 - \frac{1}{x^2}[/tex]
This is what I get when I read your expression using standard parsing rules for mathematical expressions.
If you mean hte above then you do not need to change anything. However, if you mean
[tex]f(x) = 6 - \frac{1}{x(x-2)}[/tex]
then you need parentheses, like this: f(x) = 6 - 1/(x(x-2)). If you mean
[tex]f(x) = \frac{6 - (1/x)}{x} - 2[/tex]
then you need parentheses, like this: f(x) = (6 - (1/x))/x - 2. Finally, if you mean
[tex]f(x) = \frac{6 - (1/x)}{x-2}[/tex]
then use parentheses like this: f(x) = (6 - (1/x))/(x-2).
Well, considering that: $$\frac{d}{dx}\frac{6-\frac{1}{x}}{x-2}= \frac{-6x^2 + 2x - 2}{x^2(x-2)^2}$$... it's probably a good guess ;)
@ishahad:
What is needed now is a follow up from you.
It is tricky to guide you through this one without effectively providing the answer so I want to know where you are stuck. Please show us your best attempt.
