Help please .Transmission line parameters in per unit
8 replies · 3K views
Serena_hm
Help please...Transmission line parameters in per unit
hello there
I'm trying to work on a program that converts electrical quantities of transmission line ( R , L , and C ) into per unit system using Matlab
the thing is that I'm finding difficulties with the formulas , how I can obtain them , each one individually !
Does anybody have clue about it or maybe any other way can be suggested instead !?
I'll be grateful
sincere regards
Obtain them from measurements on the transmission line, or from its catalogue properties, or compute them from the line's geometry?
From macroscopic parameters, v-2=L*C and Z2=L/C is enough, where L and C are per unit length. Resistive losses per length link R and L*2piF, where R is per unit length at the measurement frequency - very important, since skin effect let's it differ completely from DC resistance. Something like exp(-x*R/L2piF) but please check for the constants.
From a line's geometry, many simple form do have an algebraic solution... Coaxial, bifilar, wire over ground, two wires over ground. But not when a dielectric fills a part of the space, for instance in a printed circuit line; experimental formulas then.
Again, from Z you get C and L then, feeding the permittivity in as often needed.
I have not tried this, but I am not sure you can use R', L' and C' ( per unit length) to simulate a transmission line that accurate. To get accurate representation, you have to have a model that accommodates very high frequency. Remember, if you read over the explanation of this RLC model, you have to take the infinitesimal length to form the model, and it is almost like in differential or point form. You don't just use 1 meter or some particular length to start simulating.
There are well established formulas, why don't you want to use those.
hello there !
thanks for your reply ...well I'm talking about per unit system where we use Vbase & Sbase in the circuit , I'm afraid that I got a little bit lost ...did you get what I exactly mean !?
the program is supposed to calculate the parameters with knowing Vbase , Sbase , length and also the conductor type
Are there any formulas can be used !?
Serena_hm said:
hello there !
I don't know your program. All I am saying is using R', L' and C' might not be the best way as I described above. I have to look around later, I have to go out for a few hours. Time for the gym.
well , thanks for your reply all and I really do appreciate your help
actually I'm working on Powerworld simulator and in that program I'm supposed to enter the transmission line parameters in per unit system " p.u " for ( R , L , and C ) I'm going to work on practical grid that has transmission line parameters in (ohm/km ...etc )
I do know that there is an option in the program to make these calculations ( as separate file called TransLineCalc ) but sadly it didn't work with me cause I don't have the full version of the program & I've contacted the help center in order to provide me with the full version but they replied that they only deal with companies or universities...
you may need to check the link below so you can really understand what I'm really looking for
http://www.powerworld.com/products/translinecalc/overview
sincere regards !
You are talking about power line, power distribution! I was talking about RF transmission lines. Forget what I said, forget it all. I don't know your transmission lines at all! Sorry.
no worries , I finally got what I'm really looking for
R = R'/Zbase...(p.u)
x = X'/Zbase...(p.u)
B = B'/Ybase...(p.u)
where R' : Total series resistance in Ohms
X' : Total series inductive reactance in Ohms
B' : total series susceptance in Siemens
Thanks to you all for your time & attention !
