Help please with De Moivre's Theorem (raising a complex number to a power)
  • Thread starter Thread starter Eng studies
    Polar Theorem
The discussion revolves around applying De Moivre's Theorem to raise a complex number to a power, specifically focusing on the complex number z = -2 + j. Participants are attempting to convert this number into polar form and subsequently use the theorem to compute z^8 and plot it on an Argand diagram.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants are exploring the conversion of the complex number to polar form and questioning the accuracy of their calculations. Some are seeking clarification on the application of De Moivre's Theorem and the correct interpretation of angles in the context of complex numbers.
There is ongoing dialogue about the correct application of the theorem and the polar conversion process. Some participants have offered guidance on the use of LaTeX for mathematical expressions and have pointed out potential errors in angle calculations. Multiple interpretations of the problem are being explored, and participants are encouraged to share their progress.
Participants are working under the constraints of homework guidelines, which may limit the amount of direct assistance they can receive. There is also a discussion about the proper notation for angles and the implications of using incorrect symbols in mathematical expressions.
Eng studies
Convert to polar form and find z'8 using de moivre theorem, plot on argand diagram
Demoivre - (cos0+jsin0)'n = cosn0 +jsinno
Hi all any help on this would be great I cant seem to progress with the theorem,
z= -2 + j > R sqrt (-2)'2 + (-1)'2
r = 2.24
0= Arctan(-1) = 26.57 Polar form = 2.24(cos(26.58)+jsin(26.58)
-2
Could some one work a similar example to assist me through applying this ?
Thanks
Eng studies said:
Homework Statement: Convert to polar form and find z'8 using de moivre theorem, plot on argand diagram
Relevant Equations: Demoivre - (cos0+jsin0)'n = cosn0 +jsinno
Have you tried a Google search for videos on this subject? I did a quick search and found a number of videos that look like they would be helpful for you.
I have had a quick look maybe ill spend some more time just struggling to apply to question set above
I hope you know that 'cos0' should be a theta, ##\theta##, not a zero. It is true for any angle, ##\theta##.
Demoivre: ##(\cos \theta + j \sin \theta)^n = \cos n\theta + j \sin n \theta##.
r = 2.24
I don't know what this is relevant to. Exactly what is the statement of the problem?
-2
None of that makes sense to me. I don't know what it is relevant to.
FactChecker said:
I hope you know that 'cos0' should be a theta, not a zero.
Ohh, thanks for that. I could not decipher the OP's question to save my life. :smile:
Bear with me guys i could not get the symbols to load see attached, This is where im at if you could verify the polar conversion that would be great.
Following that I need some help applying this into the theorem any relevant assistance/workings would be appreciated
Workings attached with the correct symbols
to plot z8 I presume n needs to be power of 8 but I am getting really high numbers which i do not think are correct
To post math equations, it's best to use the LaTeX engine that PF provides. There is a helpful "LaTeX Guide" link below the Edit window to get you started. Note that you put double-$ delimiters at the start and end of each stand-alone line of LaTeX, and double-# delimiters at the start and end of in-line LaTeX that does not need to be on its own line. Also, if you right-click on a LaTeX equation in a post, you get a pop-up menu to let you view the LaTeX source or view it in other formats.
LaTeX isn't supported in thread titles, so you can use simple text math in titles if you want.
Note also that PF uses a feature called "lazy LaTeX rendering" that speeds up page loads. When you first post your LaTeX in a thread, you will not see it rendered that first time. Just refresh your browser page to force it to be rendered, and then it should render whenever you come back to that page/thread in the future.
Ok Perfect ill have a play around with that going forward, Does my question make sense to you now ? is the polar conversion correct ?
It appears that the problem statement is this:
If z = -2 + j, use the Theorem of De Moivre to calculate ##z^8## and plot this as an Argand diagram.
r = 2.24
Do not use ' to indicate an exponent. If you don't use LaTeX, the symbol ^ is often used for this purpose.
-2
The above is the form for complex numbers with modulus equal to 1. As was already mentioned, don't use 0 in place of ##\theta## (theta).
##(\cos(\theta) + j\sin(\theta))^n = \cos(n\theta) + j(\sin(n\theta)##
There is a different version for complex numbers whose modulus is not equal to 1.
Thanks
Here's an example.
If z = 1 + j, find ##z^3##
Solution
##|z| = \sqrt{1^2 + 1^2} = \sqrt 2##
##\theta = \arctan(1/1) = \frac \pi 4##
In polar form ##z = \sqrt 2(\cos(\pi/4) + j\sin(\pi/4))##
Then ##z^3 = (\sqrt 2)^3(\cos(3\pi/4) + j\sin(3\pi/4))##
To plot ##z^3##, the argument (angle) is 135° (halfway into Quadrant II) and the magnitude is ##2\sqrt 2 \approx 2,828##.
In your work shown in the attachment, you found an angle in Quadrant IV. That is incorrect- it should be in Quadrant II since that's where z is.
If you have a negative value [real or imaginary] the atan does not return the actual argument. In your case the argument is ACOS(-2/2.24) only.
In this case, the actual argument is ##\tan^{-1}(-2) + \pi## or in degrees, about 153.4°.
More precisely, ##\cos^{-1}(\frac{-2}{\sqrt 5})##.
Thanks all I will read through this in detail and have another attempt will post progress when done
find the angle, multiply it by 8, and then raise the length to the 8th power. that gives angle and length. then use trig to plot it in coords (i.e. find cos and sin of the angle, then scale by the length).
I ended up getting 625(cos154.48 + jsin154.48) but I am having a hard time understanding how 625 is plotted on an argand diagram?
To plot a complex number of the form ##A(\cos(\theta) + i\sin(\theta))##, rotate counter-clockwise through an angle of ##\theta## (measured from the positive real axis), and then go out that ray A units.
That's just the length/modulus of the number. The length of the line joining the origin with the ( representation of the) number.
  • · Replies 33 ·
  • · Replies 18 ·
  • · Replies 18 ·
