Help regarding fast response photodetection
  • Thread starter Thread starter Shikhar
    Response
The discussion revolves around the design of a high-speed photosensor for a college project, specifically in the context of detecting intense light from a bomb explosion. Participants explore different types of photosensors, including photodiodes and phototransistors, and discuss their suitability for triggering other sensing devices.
  • Homework-related
  • Shikhar inquires about the best type of photosensor for high-speed detection, specifically asking whether a photodiode or phototransistor would be more suitable.
  • One participant suggests using a photodiode with a reverse bias of 5-10 volts in a current-to-voltage converter configuration for fast response times.
  • Another participant mentions the use of photomultipliers and vacuum photodiodes for measuring sub-nanosecond transit times, indicating their effectiveness in fast detection.
  • A participant argues that PIN photodiodes are the fastest option due to their design, which allows for rapid carrier drift when reverse biased.
  • Concerns are raised about the speed of phototransistors, which may be slower due to reliance on carrier recombination and the time required to reach operating points.
  • Shikhar questions the principle behind reverse biasing photodiodes and suggests that it enhances the speed of carrier movement to the measuring circuit.
  • Another participant explains that the capacitance of a reverse-biased PN junction decreases with increased reverse bias, which is crucial for faster operation.
  • Shikhar asks if a comparator can be used for the voltage output from the photodiode circuit to achieve TTL output for triggering instruments.
  • One participant confirms that a fast comparator can be used after the opamp to provide logic levels, while also discussing the importance of hysteresis in the comparator feedback.
Participants express differing opinions on the best type of photosensor and the implications of reverse biasing. While some suggest photodiodes as the optimal choice, others highlight the potential of photomultipliers and PIN photodiodes. The discussion remains unresolved regarding the best approach and the specifics of implementation.
Participants discuss various configurations and principles related to photodetection, including the effects of reverse bias on capacitance and speed. However, there are no settled conclusions on the best design or approach for the photosensor.
Shikhar
Hi there...
i'm working on my college project and wanted to design a high speed photosensor. The intensity of light source is quite high (actually a bomb explosion), so noise signals are not a problem. The photosensor is required to trigger other sensing devices.
So which type of photosensor would suit me best- a photodiode or phototransistor?? and why...
i would really b obliged if you could provide me with the required circuit(implementation point of view)...
Thanks
Shikhar
Shikhar said:
Hi there...
Thanks
Shikhar
Use a photodiode with a reverse bias of 5-10 volts or so. Use it in the traditional current-to-voltage converter configuration, with a fast opamp. You should be able to get fairly fast response on the order of a few us, I think.
Quiz question -- why should you reverse bias the photodiode instead of running it with zero reversse bias? It's an important concept related to the speed...
An even faster option would be to use a fiberoptic receiver module, which has the photodiode and converter circuit built together. You can get them with logic output capability. HP made some that I've used in the past.
I have used photomultipliers (RCA 2020) and vacuum photodiodes (RCA 935) to measure sub-nanosecond transit times, using an analog time to voltage converter..
Bob S
Bob S
Show-off! :biggrin:
thanks Berkeman!
hmm..i think...it's because photodiodes work on the principle of generation of electron-hole pairs when a light of appropriate wavlength strikes the junction. Now, more the reverse bias, faster would be the speed with which there carriers reach the measuring circuit...
am i right?
please tell me one more thing..can i use a comparator for the voltage output from the photodiode circuit so that i get a TTL output (this is what i actually want as the light sensing is just to trigger other instruments)
Shikhar
The PIN photodiodes will get you there fastest. Most of the carriers form in the I region and as long as you apply a reverse bias to the device, they will drift out rapidly (i.e. 5ns) driven by the e-field.
You will need some gain with the PIN diode. Most times, it is used in a trans-conductance amplifier configuration. However, if you have plenty of signal, and really want a really fast response, it may prove easier to output it into a 50-100 ohm load and follow it with a video amplifier.
Photo transistors are slow dogs which often rely upon slow carrier recombination to improve their gain. It also takes time for an unbiased photo transistor to reach operating point. If your looking for just the flash, you can bias the photo transistor and it should turn on fairly quick (not near as fast as a PIN). It just won't turn off very fast.
- Mike
thanks Berkeman!
am i right?
Shikhar
Yes, you can follow the opamp with a comparator to give you logic levels. Be sure to use a fast comparator, and add some hysteresis to the comparator feedback.
On the quiz question, no, the main effect is capacitance. How does the capacitance of reverse-biased PN junction vary with reverse bias voltage? Why is that important in the photodiode detector case?
the interface of a reverse biased pn junction is depleted of majority carriers (depletion region = comprised of minority carriers, which respond extremely fast compared to majority carriers, meaning low capacitance). Light impinging on the pn junction excites majority carriers into the conduction band, and they are swept across the junction by the imposed electric field.
a forward biased pn junction has a build up of majority carriers, resulting in an extremely thin depletion region. Carriers excited into the conduction band move across the junction slowly because of this build up.
ohkk...i get the clue!
on reverse bias, width of depletion region increases, so capacitance decreases as C is inversely proportional to 'd'.
NOw as time constant = RC, so time constant decreases ie. faster operation!
  • · Replies 27 ·
  • · Replies 0 ·
18K
