Help Solve Munkres Question: Limit Point Compact Subspace in Hausdorff Space
  • Context: Undergrad
  • Thread starter Thread starter facenian
8 replies · 4K views
facenian
TL;DR
Problem with a limit point compact space
Hello, I have a problem with a question in Munkres topology book. Munkres asks if a limit point compact subspace X in a Hausdorff space Z is closed.
I tried to prove it by contradiction by taking an infinite set in X and suppose it has a limit point that is not in X, however, I could not find a contradiction. I suspect that an example exists where X is not closed. Can somebody please help?
Are you familiar with the space of linearly ordered ordinals? It provides a counterexample to your claim.
Sorry, I don't understand your answer. My claim is that I suspect that there exists a Hausdorff space in which a limit point subspace is not close. Do you mean that I can find a counterexample in the linearly ordered ordinals that confirms my suspicion?
Exactly. See e.g. here:
https://math.stackexchange.com/q/1404003/661543
facenian said:
Summary: Problem with a limit point compact space
Just to narrow it down, hopefully get closer to an answer, you need to exclude metric, and compact Hausdorff ( of course, metric spaces are Hausdorff, so there is overlap). So it comes down to, if possible, to a setting in which limit-point compactness does not imply compactness. Hope I did not just tell you something you knew.
Yes, in a metric space limit point compactness is equivalent to compactness, so a counterexample cannot be found there. However, I don't know why you also want the exclude the case when Z is compact.
Because compact+Hausdorff ##\rightarrow ## closed.
A compact set X in a Hausdorff space Z is closed however, there could exist(I believe) a limit point compact set that it is not compact which is not closed and it is inside a Z compact Hausdorff space, i.e., the counterexample could exist whether Z is compact or not.
Yes, that is what I was trying to get at, we need to find a setting where the two do not coincide.
