Help Solving Physics Test with Mat Pulling Exercise
The discussion revolves around a physics problem involving a contestant pulling a 50 kg landing mat across a gym floor. The problem includes calculating changes in kinetic energy, work done, and energy converted to heat over a 10-second interval while considering friction and applied force at an angle.
  • Mixed
  • Participants discuss various methods to calculate kinetic energy and work done, with some suggesting the use of formulas for kinetic energy and acceleration. Questions arise about the correct approach to finding average kinetic and potential energy, as well as the energy lost to heat.
Several participants have offered hints and guidance on how to approach the calculations, particularly regarding the relationship between force, acceleration, and kinetic energy. There is ongoing exploration of different interpretations of the problem, with no clear consensus reached yet.
Participants are working under the constraints of a homework assignment, which may limit the information they can use or the methods they can apply. Some assumptions about the forces acting on the mat are being questioned.
PrimeTime89
Could some one possible help me with the problem i have for physics, it was a test question and i didn't get it at all.
A contestant will be required to pull a 50 Kg landing mat, from rest across the gym floor for 10 seconds. Mat has been selected for this event. he has calculated that if he could supply a constant force of 200N at an angle of 60 degrees to the horizontal, the speed of the mat after 10.0 seconds will be 8.00 m/s. homework also figured out during this time a constant frictional force acts on the mat.
a) what will be the change in Kinetic Energu of the mat during this 10 second period
b) how much work will mat do on the mat?
c) how much kenetic energy will be converted into energy heat during the 10 second interval?
It would be much apriciated if someone would be able to help me.
Thanks
If you could tell us what you have attempted for the problem thus far we would be able to help. A hint for the first part of the question to get you going is simply subtract the initial kinetic energy from the final kinetic energy.
i just need to know how to get the avg potential and kenetic energy?
any help?
[tex]K.E. = \frac{1}{2}mv^2[/tex]
that's how you find the average potential gravitational and kenetic energies, then i am able to find the themal heat given off right, just to tell you guys i have done both a and b,i'm just stuck on c, wasn't quite sure how to do it
Work out the acceleration of the mat and what speed it should be after ten seconds and compare it with the actual speed. I hope this hint helps.
didn't get it , so use, a=(V2+V1(t))/2, then v=d/t, then divide the 2 then use those finidings to calculate the EK and EG?
Work out the horizontal component of force. F=ma frm this equation you can work out the acceleration and then see how fast it should be going after 10 seconds. Compare the kinetic energy of this with the actual kinetic energy. The difference will be the energy wasted as heat.
okay thank you very much
so then he lost 600 N to thermal energy right?
No its considerably bigger and energy is measured in joules not Newtons. If you show me your working I can tell you where you went wrong.
okay
well i found the acceleration to be 4m/s2
then i found the distance to be 200m
then i found the speed to be 40m
but i think i did it wrong because i used the avg speed,
sdo i put in E.K. = .5(50)(20)2
and got 1000
then E.K. = .5(50)(4)2
then go 400
i think i know why it's wrong but not sure
would it be 38400??
First of all the acceleration is given by Fcos(60) = ma because you only need the horizontal force pulling the mat. Secondly there's no need to find the distance just multiply the accelerat by the time (10 seconds) to find the speed it should be going if all the force went puerely into acceleration. Thirdly calculate the kinetic energy of the speed you find and the speed that it was actually going (8m/s) and take the difference of the two. No need to use average speed at all.
is .25 the accel and is the 38400 J right or wrong?
38400 is wrong and the acceleration should be 2 m/s^2
12K
