Help solving the initial value problem
The discussion revolves around solving an initial value problem involving a differential equation of the form 2(√x)y' + y + 4(√x) with the initial condition y(1) = 2. Participants are exploring methods for separating variables and integrating the equation.
  • Mixed
  • Participants discuss the correct approach to separating variables and integrating the equation, with some expressing uncertainty about when to apply the initial condition. There are questions about the role of constants during integration and whether they should be adjusted based on the initial condition.
The conversation includes various interpretations of the integration process and the handling of constants. Some participants have offered guidance on finding the integrating factor and the implications of the initial condition, while others are questioning assumptions about the constants involved.
There is some confusion regarding the proper form of the differential equation and the treatment of constants during integration, as well as the application of the initial condition in determining the constant of integration.
middieman147
Given:
Solve the initial value problem 2(√x)y'+y+4(√x) ; y(1)=2
I am having trouble separating the x's and y's in order to integrate. I keep coming up with:
dy/dx +y/(2(√x))=2...
What do I keep missing here? I am pretty sure you leave the y(1)=2 alone until you are finished with the integration, in which case you plug in x=1 and y=2 to solve for the constant. Is this the correct thought process for this problem?
Thanks.
Or can I substitute in the y(1) for the 2 on the right side of the equation and make all the other x's equal to 1?
let
and
find the integrating factor
and then use
hope that help :)
Ok so now I have:
y'-y/(2√(x))=2
p(x)=-1/(2√x) q(x)=2
u(x)=e∫(-1/(2√x))=e-√x
y=e√x(2e-√x)+C
y=2+C
this is the solution for all values of x with C=0, correct? Or am I forgetting a step?
Thanks
you firstly have to integrate the right side
before you multiply it by
Ok:
y=-4sqrt(x)-4+C with C=10 is the answer given the IC y(1)=2?
when u divide the right side after integrating by
, u should also divide the constant too so it should be
middieman147 said:
Given:
Do you mean [itex]2\sqrt{x}y'+ y= 4\sqrt{x}[/itex]?
Thanks.
yes I do.
thanks.
wouldn't that just be another constant?
so instead of writing Ce^sqrt(x), you could just consider it a new constant
C is a constant, but [itex]Ce^\sqrt{x}[/itex] is definitely not a constant.
isnt that irrelevant since there is an IC? wouldn't the x in that expression =1 and then just equal C multiplied by another constant?edit: Are you saying i should divide 10 by e^1 to find the constant?
No, that's not irrelevant.
In using the Initial Condition to evaluate the constant, C , you do set x=1, but in the overall solution there is a term [itex]Ce^\sqrt{x}[/itex], unless the Initial Condition gives C=0, which is not the case here.
