Help understanding current source
The discussion revolves around a basic circuit problem involving a current source and a resistor. Participants are tasked with expressing the voltage and current across the resistor in terms of the current from the source and the resistance of the resistor.
  • Exploratory, Conceptual clarification
  • The original poster attempts to relate the current and voltage using Ohm's Law and Kirchhoff's Laws but expresses uncertainty in deriving the relationships for the resistor's current and voltage in terms of the given variables.
  • Some participants clarify the fundamental differences between current sources and voltage sources, discussing how each affects current and voltage in a circuit.
  • Questions arise regarding the implications of the current source's behavior in the circuit.
Participants are exploring the basic concepts of current sources and their relationship to circuit behavior. Some guidance has been provided regarding the nature of current sources, and there is an acknowledgment that the current through the resistor is equal to the current from the source.
There is an emphasis on the original poster's lack of familiarity with current sources, which may affect their understanding of the problem. The discussion includes a note on the abstract nature of current sources compared to more familiar voltage sources.
mango21
This is a really basic problem, just a closed circuit with a current source and a resistor. We are meant to give the voltage and the current across the resistor in terms of the current from the source and the resistance of the resistor. (From the diagram, express Vr and Ir in terms of I1 and R). I have never encountered a current source before and am having trouble learning to deal with it.
Ohm's law: V = IR
Kirchoff's Laws: sum of voltages = 0, and current into a node = current out
My thought was to say that I1 = Vs/Rs, so Vs = I1/Rs = Vr = Ir/R.
But then I don't know how to solve these for Ir and Vr in terms of I1 and R.
Any help understanding the concept would be greatly appreciated! Thanks :)
Ohm's law: V = IR
Welcome to the PF.
There is nothing tricky here. The current source sets the series current that flows around the circuit. The resistor value is what determines what voltage is dropped across it, just based on Ohm's Law V=IR.
You are probably familiar with voltage sources, even if you didn't use the name. You can think of a voltage source as being like a battery. It always has the same voltage across its terminals, but the current depends on the circuit that is connected to it.
A current source is the opposite way round. It always produces the same current, and the voltage across it depends on the rest of the circuit.
If you increase the resistance of a circuit connected to a voltage source, voltage stays the same but the current decreases. If you increase the resistance connected to a current source, the current stays he same but the voltage increases.
Unlike a battery, it doesn't make any sense to have a current source "not connected to anything", because its output current has to go somewhere.
In real life you have to make a current source from a circuit containing transistors or op-amps, so the idea is a bit more abstract than a battery. But current and voltage sources are both very useful ideas in circuit analysis.
Note, all the above is a bit over-simplified. For example both current and voltage sources can produce a variable output that is related to something else in the circuit. But the important thing is to understand the basic idea before making it more complicated.
Thanks! So in this case Ir = I1?
Yep! :smile:
  • · Replies 18 ·
