Help with an airplane problem (relative velocity)
The discussion centers on calculating the wind velocity affecting an airplane flying due west at an airspeed of 218 km/hr. After 0.510 hours, the pilot finds herself 124 km west and 16 km south of her starting point. The key conclusion is that the wind must have both a southbound and a westbound component, as the plane's ground speed differs from its airspeed due to wind influence. The calculations reveal that the plane would have traveled 111.18 km west without wind, indicating that the wind's westbound component is necessary to account for the additional distance traveled.
  • Understanding of vector resolution in physics
  • Familiarity with basic kinematics equations
  • Knowledge of airspeed versus ground speed concepts
  • Ability to apply the law of cosines in vector problems
  • Learn vector resolution techniques for analyzing wind effects on flight paths
  • Study the law of cosines for solving triangle problems in physics
  • Explore kinematic equations to understand motion in two dimensions
  • Investigate the impact of wind direction on flight navigation and safety
Aerospace engineers, physics students, pilots, and anyone involved in flight dynamics or navigation will benefit from this discussion.
ccsmarty
An airplane pilot sets a compass course due west and maintains an airspeed of 218 km/hr. After flying for a time of 0.510 hr, she finds herself over a town a distance 124km west and a distance 16 km south of her starting point. Find the magnitude of the wind velocity (in m/s).
You're making the assumption that wind velocity is southbound... it might not be...
What would be a better assumption then? I could use any help because I've been working on this problem for a while, and I'm not getting anywhere :(.
You should calculate the plane's velocity with respect to Earth (ground speed) first. (I'm no pilot, but i would have thought that if she set her compass west, she'd end up due west, but i guess not, according to the problem).
Try solving other way, so that you can avoid geometry.
like
v[ab]= v[ar]+v[rc]+...+v[pq]+v[qb]
and v[xy] = -v[xy]
You know the wind has a component southbound... because the plane ends up south... you don't know whether it has a east bound or west bound component...
I like rootx's method... divide wind into 2 components... vsouth, and vwest (ie assume wind is southwest, if vwest comes out negative then it was pointed southeast).
You can easily calculate the southbound component... you know the southbound displacement...
For the westbound component you need to add the plane's velocity...
We can solve it by vectors. Learning physics has made a good point that the wind's velocity can be in any direction so in that case we can resolve the vector and proceed.
But suppose that the wind is not even southwest or southeast but it is some other add angle like say 65 or 35. Is this case possible/ I think it is . So in this case what to do? Hence i feel that the wind's direction is only in the south. And then we can do it by the normal equations.
But the plane ends up south... so the wind must have a southbound component, not northbound...
Also, 0.51h * 218km/h = 111.18 km, so the plane alone would only go 111.18km in 0.51 hrs... But the total westbound displacement is 124km as given in the problem... so the wind has a westbound component.
They gave the time it took... I agree that if we didn't have the time, we'd have to assume wind direction... but since the time is given we don't need to.
I never was too fond of the law of cosines, but it certainly seems applicable here, where the plane's air velocity is given, and it's ground velocity, and angle between each, is easily calculated from the given data...
Yes, you are right. I totally forgot that the time was given.
  • · Replies 17 ·
