Help with angular momentum question
To find the total angular momentum of the system consisting of two particles and a thin rod, the individual angular momenta of the particles must be calculated first. The moment of inertia for the rod can be determined using the distance between the two particles as the length L in the formula (ML^2)/12. The angular frequency of the system, computed as 0.363, is essential for calculating the total angular momentum. The total angular momentum is then the sum of the angular momenta of the particles and the rod, factoring in the angular velocity. Clarification on the length of the rod, which is the distance between the two particles, is critical for completing the calculations.
pakmingki2
A. At a particular instant, a particle of mass M = 3 kg is at the position (x,y,z) = (4,4,6) m and has velocity (2,1,-2) m/s.
B. An identical particle is placed at (x,y,z) = (-4,-4,-6) m, with velocity (-2,-1,2) m/s.
Find the angular momentum of the pair of particles about the origin.
C. A thin rod of mass 9 kg is added between the two particles (Irod = M L^2/12). Since the particles are moving perpendicular to the line separating them and in opposite directions (you should convince yourself that this is true), then the particles + rod system rotates about its center of mass. Compute the angular frequency of rotation of the rod + particles system.
D. Compute the magnitude of the total angular momentum of the system (particles plus rod).
ok, so i got parts a,b,c pretty easily.
A. <-42, 60, -12>
B. <-84, 120, -24>
C. .363
Ok, so for part D, the main approach i used was total angular momentum = sum of all individual components in the system.
So, i can easily find the angular momentum of the two particles, but the problem is finding the moment of inertia of the thin rod. The formula for inertia is (ML^2)/12, but i can't seem to get the length L from anywhere in the problem.
Any help is appreciated.
thanks alot!
Distance between the two particles is the length of the rod.
how do you find the angular momentum of the particles?
The angular momentum of the particles = Total moment of inertia*angular velocity=(Moment of inertia of rod + moment of inertia of particles) *angular velocity.
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 17 ·
15K
