Calculate ΔE: Endo- or Exothermic? Solving Problems with ΔE Equation
  • Thread starter Thread starter bigzabuda
To calculate ΔE and determine if the processes are endothermic or exothermic, one must consider the heat absorbed or released and the work done. For case (A), the system absorbs 105 kJ of heat and does 29 kJ of work, indicating it is endothermic since it absorbs more energy than it releases. In case (B), with q = 1.50 kJ and w = -657 J, the negative work suggests the system is also endothermic. For case (C), the system releases 57.5 kJ of heat while doing 22.5 kJ of work, making it exothermic as it releases more energy than it absorbs. Understanding these principles clarifies the classification of each process.
bigzabuda
The problems asks,
Calculate ΔE, and determine whether the process is endothermic or exothermic for the following cases:(A) A system absorbs 105 kJ of heat from its surroundings while doing 29 Kj of work on the surrounding;(B) q = 1.50 kJ and w = -657j; (C) the system releases 57.5 kJ of heat while doing 22.5 kJ of work on the surrounding.
I am confused with the question, I am pretty sure the equation is ΔE = q+pΔv
im not sure what to do can anyone help me, thanks.
It is easier than that.
You have two values:
- Absorbed heat. It is an amount of energy which goes into the system
- Work done by the system. It is an amount of energy which goes out of the system.
Now a system is exothermic if it releases more energy than it absorbs, and endothermic if the other way around.
  • · Replies 16 ·
11K
11K
