Help with calulating a cyclic rate
  • Thread starter Thread starter Senngenn
    Cyclic Rate
The discussion revolves around calculating the cyclic rate of a semi-automatic firearm's bolt mechanism. Participants explore the relationship between the bolt's mass, travel distance, and the forces involved in regulating its speed, particularly in the context of reducing the cyclic rate from 2500 RPM to between 900 and 1000 RPM.
  • One participant seeks to determine the speed of a bolt with a mass of 210 grams that travels 2 1/4 inches in a straight line.
  • Another participant questions the weight of the bolt, suggesting that 210 kilograms seems excessive, which is later corrected to 210 grams.
  • Participants discuss the driving mechanism of the bolt, identifying springs as the return mechanism after firing.
  • Clarifications are sought regarding the meaning of "2500 RPM," with some confusion about whether this refers to rotational speed or linear motion.
  • Details about the spring characteristics, such as preload, deflection, and number of coils, are provided to help calculate the spring rate and its effect on the bolt's motion.
  • One participant mentions using an online spring calculator to derive the spring rate and average closing force based on the provided specifications.
  • Another participant expresses a desire for clarification on the total compression of the spring during operation.
  • There is a request for further explanation of the calculations related to the bolt's closing time and the forces involved.
Participants express varying levels of understanding regarding the cyclic rate and the mechanics of the firearm. There is no consensus on the exact calculations or the implications of the spring characteristics on the cyclic rate.
Some participants note the importance of specific spring characteristics, such as the number of free coils and the spring rate, which are necessary for accurate calculations. There are also unresolved questions about the relationship between the firing mechanism and the cyclic rate.
Senngenn
Hello, sorry if i do not ask the question correctly but any help would be great.
i need to find the speed of an item and I'm not sure what i need to find this out?
well a cyclic rate of this item?
Thanks
Hi Senngenn. Welcome to PhysicsForums.
I see about 40 people have read this but no one offered an answer. It might be that we are not understanding your question.
Are you asking about a certain situation? Can you describe that situation?
You said "cyclic". Is this something rotating?
It might help to post a drawing.
I hope i can explain better,
the item Wt. is 210 grams the maximum travel is 2 1/4" it travels in a strait line.
We are a Firearms Mfg. we have a semi auto bolt when fired it travels the 2 1/4" we are trying to regulate the speed of our sub machine. when we do not regulate the cyclic rate it has a speed of 2500rpm we are trying to slow that to about 900 to a 1000 rpm. so i think I'm really looking for is to determine the speed involved with his moving mass? because when the round is fired the explosion is what drives the bolts speed.
Thanks for your time.
Senngenn said:
the item Wt. is 210 kilograms the maximum travel is 2 1/4" it travels in a strait line.
210kg sounds a bit high for a firearm bolt, no?
sorry 210 grams
What drives the bolt on the return segment of the cycle?
Springs.
Can you explain what this means? What is spinning at 2500 RPM and how is this involved in the firing of your gas-driven firearm? Can you upload a couple pictures or a diagram? Thanks.
What is the spring rate, installed preload and, if you have determined it, the maximum deflection during firing of your spring set?
Nothing is spinning 2500 rpm is in a strait line motion
also our firearm is designed not on a gas system but a delayed roller system it uses the pressure from the round going off to drive the bolt back words.
i"m not sure what the spring rate is but we preload the springs about 3/4" and they are compressed 2 1/4" due to the firing. if this helps the spring is 6 1/4" long .275 OD and the wire diameter is .035
Another spring characteristic that is required to determine its spring rate is the "number of free coils" which is the sum of all of the coils excluding the two partial end coils. With that plus the above information it should possible to determine an approximate spring rate; but, I haven't done that particular spring analysis before.
If you know your spring manufacturer and their part no. for your spring would it be possible for you to contact them to get the spring rate because if your spring is one made specifically for your use then that is the only way to determine the true spring rate for your spring?
Alternatively, with that same information, if they are a principal manufacturer and your spring is a stock item for them, I may be able to find an online catalog that will give me the spring rate for your spring.
This information is important because with the installed and compressed spring lengths you have given it is possible to determine the average spring driving force and, from that, the average bolt closing acceleration; and, subsequently, the bolts' travel time during closing. With that information, then the gas powered opening time is equal to the time of one rpm minus the calculated bolt closing time (and the average bolt opening driving gas pressure can also be calculated).
Sorry there are 52 coils and the lead is .125 on each coil
I need a bit of clarification on spring's total compression. Is the 2.75" travel in addition to the .75" installed deflection for a 3.50" total max spring compression?
We preload the spring 3/4" and the travel of the bolt is 2 1/4" for a total compression of the spring of 3"
Thanks, I just got offtrack on decimal part of the travel length
no problem thanks
Using those spring specifications and some circular load at 3" deflection trial values in an online spring calculator from Newcome Spring Corp (see below) it appears your spring rate is 3 lb/in. and its load at the 3" in deflection is 9 lbs. and results in an installed preload of 2.25 lbs at 3/4"
Edit: Which results in a 5.625 lb average closing force.
https://www.newcombspring.com/springulator/compression-spring-calculator
Now, with that information, after a bit of a break, I will take a run at my above described calculations for the closing time, etc.; unless you would prefer to do those yourself.
No please have at it but if you could explain how you came up with the final numbers I would appreciate that thanks for all your help.
Okay, I guess "rpm" is rounds per minute of machine gun fire, and you'd like to slow that down to 900-1000 rounds per minute with some control mechanism or damping. Is that correct?
What are you using for the control of the firing pin? The initial release of the firing pin is via the trigger sear, and after that the firing pin is locked in place proud for the automatic fire? If you had control of the delay for the firing pin release for each cycle in automatic fire mode, that would be the easiest way to regulate the fire rate, IMO.
I have done a quick calculation and I am running into an immediate conflict in that the travel time for the bolt closing based upon the bolt mass and the average spring force is greater than the total cycle time at 2500 RPM.
In that respect, what, if anything, prevents the bolt from traveling more than your specified 2.25" other than the the resisting force of the spring at 3" of compression?
Edit: Attached below is a screen print of my initial analysis:
Is there someplace where the spring diameter and spring material is given, or did I miss it?
See Post #13 for spring OD and wire diameter. The spring material has not been specified but I used the chrome-silicon selection in the spring calculator
With respect to my question about what limits the bolt travel, if you have a backstop that determines the 2.25" bolt travel, some percentage of the energy from the bolt opening is going to be added to the spring energy and that is going to increase the bolt's closing speed and reduce the bolt closing time.
Determining the bolt opening energy requires knowing the bolt's opening terminal velocity which requires knowing the maximum gas chamber firing pressure and the shape and dimensions of the chamber and the bolt diameter in the chamber.
Estimating the percent of energy returned from the bolt/backstop impact requires knowing the material hardness of the bolt and backstop components. The harder the materials, the higher the percent of energy return.
