Capacitance Homework Help: Equations, Tips and a Helpful Datasheet
  • Thread starter Thread starter gamma-guy
    Capacitance
The discussion centers on solving capacitance homework questions, specifically identifying the correct equations and methods for determining series and parallel configurations. The user successfully calculated capacitance for one part but encountered discrepancies in voltage calculations, needing clarification on charge division among capacitors. Additional equations related to energy stored in capacitors and capacitance based on physical parameters were suggested for further understanding. The user requested assistance with a fourth question, prompting others to encourage attempts at problem-solving. Overall, the focus is on clarifying concepts and calculations related to capacitance.
gamma-guy
reminder: members should give each h/w question its own thread
Ive got these questions and I am not quite sure where to start. if someone could point me to the equations to use for Q1 and Q4, id appreciate it. As for Q2 and Q3, I need help with how to determine if its in series or parallel and how to properly add them.
q=CV
Here is a datasheet I was told would be helpful.
so I got 3a) by doing C23 series, = (1/250 +1/250)-1 = 125uF. Then parallel with C1 = 125 + 250 = 375uF. Then series with C4 = (1/375+1/250)-1 and got 125uF.
For b) I thought of doing q= CV = 150e-12*16V = 2.4e-9. Then because capacitance is the same, V = q/C = 2.4e-9/250e-12. But that gives me 9.6V. I am supposed to get 6.4V. What am I doing wrong?[/B]
Your answer for 3a looks correct. For 3b check if you calculated the voltage on C1 or C4. I note that 16-9.6=6.4
As for equations, look up the one for the energy stored on a capacitor and the one for the capacitance in terms of plate area and separation.
If you can do Q3a you can do Q2.
Your analysis is correct but check the calculations for C4 again. The answer is 150pF as given.
What do you mean by " the capacitance is same"? There will be division of charge between C1 and C23. Voltage across C1, C23 and C123 is same.
Thanks guys, ill look over it.
Any help with Q4?
Any help with Q4?
Can you make an attempt? What are your thoughts on how you might approach the problem? What would you do if the rod was just a solid cylinder of iron or copper?
  • · Replies 67 ·
11K
  • · Replies 19 ·
