Help with derivation of torque equation T = p x E
  • Context: Graduate
  • Thread starter Thread starter iScience
    Derivation Torque
The discussion focuses on the derivation of the torque equation, specifically \(\vec{\tau} = \vec{p} \times \vec{E}\). Participants clarify that torque, defined as \(\vec{\tau} = \vec{r} \times \vec{F}\), relates to the angular momentum \(\vec{J}\) of a particle, where \(\vec{J} = \vec{r} \times \vec{p}\). The conversation emphasizes the importance of understanding the definitions and relationships between these physical quantities. The final consensus is that the definitions provided are consistent with standard physics textbooks.
  • Understanding of vector cross products in physics
  • Familiarity with torque and angular momentum concepts
  • Knowledge of force and linear momentum definitions
  • Basic proficiency in mathematical notation used in physics
  • Study the relationship between torque and angular momentum in classical mechanics
  • Explore vector calculus, focusing on cross products and their applications
  • Investigate the role of forces in rotational dynamics
  • Review standard physics textbooks for definitions and examples of torque
Students of physics, educators teaching mechanics, and anyone interested in understanding the principles of torque and angular momentum in rotational dynamics.
iScience
\vec{\tau}=\vec{F}x\vec{r}
\vec{F}=\vec{E}q
\vec{p}=q\vec{d}
\vec{\tau}=(\vec{E}q)xr=\vec{E}x\vec{p}
so then how do we end up with \vec{\tau}=\vec{p}x\vec{E}?
You need to tell us what you are trying to accomplish. What do your variables represent, what is your reasoning behind each step, etc.
No, the definition is \vec \tau = \vec r \times \vec F. At least, that's the definition in every textbook I've ever used.
The torque, \vec{\tau}, about a point, O, of a force, \vec{F}, acting at point P which is located at position \vec{r} from O is DEFINED AS
\vec{\tau} = \vec{r} \times \vec{F}.
As with all quantities in Physics, we would't define it as we do, unless what we've defined is useful. In this case, there is a simple relationship between the torque about O of a force acting on a particle, and the rate of change of the particle's angular momentum, \vec{J} about O.
Namely
\vec{\tau} = \frac{d\vec{J}}{dt}.
\vec{J} is defined exactly analogously to \vec{\tau}, but substituting the particle’s linear momentum, \vec{p}, for the force, \vec{F}, on the particle, so...
\vec{J} = \vec{r} \times \vec{p}.
thanks this answers everythingnow how do i close threads?
You don't.
Zz.
  • · Replies 62 ·
