Help with derivation of two-body relativistic cross section
charlesmartin14
I am trying to derive the 2 body cross section, as given in
https://web2.ph.utexas.edu/~schwitte/PHY362L/QMnote.pdf
dσ/dΩ
I am stuck on
d√s/dp=v
where
√s=(Ea+Eb)=E
p=Ev (relativisitic energy-momentum relationship)
√s=E
E=Ec+Ed=p/vc + p/vd
pc = pd = pf
d√s/dp = d(Ec+Ed)/dp = d(p/vc + p/vc)/dp=(1/vc + 1/vd)=(vc+vd)/(vc*vd)=vf/vc*vd
Did you have a specific question?
I am trying to derive the 2+2 body relativisitic cross section, as given in
a+b -> c+d
I want the form of the cross section
dσ/dΩ ~ 1/((v_i)(v_f))
I am stuck on step (13)-(14)
and I don't understand why d√s/dp_f=v_f
Here, s is the mandelstam variable √s=(Ec+Ed)=(Ea+Eb)
and p_f is the (amplitude) of the final (I assume 3 vector ) momentum
##\vec{p}_\text{f}## is the three-momentum of particle C.
Try differentiating ##-m_c^2 = p_c^2-E_c^2## to calculate ##dE_c/dp_c##. I think the problem with your attempt is that you're assuming ##dv_c/dp_c = 0## and ##dv_d/dp_c = 0##.
Thanks ! That makes perfect sense. this is a great forum
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
