Help with digital signals (discrete fourier transform)
The discussion revolves around calculating the Discrete Fourier Transform (DFT) of a 1Hz cosine wave sampled at 4 times per second for 1 second. Participants explore the necessary steps to approach the problem, including identifying sample values and applying the DFT formula.
  • Homework-related
  • One participant expresses difficulty in starting the problem and seeks guidance on how to approach it.
  • Another participant suggests calculating the sample values for the cosine wave, indicating that 5 values should be obtained from the sampling process.
  • There is a discussion about the correct sample values for a cosine wave, with one participant proposing specific values and seeking confirmation.
  • Some participants note the difference between sine and cosine waves, particularly in their starting values and the implications for the DFT results.
  • There is a question about the process of plugging values into the DFT formula and whether to sum the outputs.
Participants generally agree on the need to calculate sample values for the cosine wave, but there is some confusion regarding the distinction between sine and cosine waves. The discussion remains unresolved regarding the exact outputs of the DFT calculation.
Some participants express uncertainty about the initial values for the cosine wave and the implications of phase shifts in the DFT results. There is also a lack of clarity on the correct application of the DFT formula based on the identified sample values.
danhamilton
I've been working on this problem for around three hours, and I'm getting nowhere... I think it may be that I don't have even the most basic grasp of the material to even get a decent start on the problem, but hopefully someone here will be able to help me...
Calculate the Discrete Fourier Transform (DFT) of a 1Hz cosine wave
sampled 4 times per second for 1 second.
<br /> <br /> X(K) = \sum_{n=0}^{N-1} x(n)e^{-j*2*\pi*\frac{k*n}{n}}<br /> <br />
Honestly, I'm stumped. I don't even know where to start. I'm not asking anyone to do the problem for me, but I'd be forever greatfull if someone could start me in the right direction.
Thanks,
Dan
Okay, start with this factoid: a 1 Hz sine wave, sampled 4 times per second for 1 second should give you 5 values (assuming you know the value at 0):
x[0]=
x[1]=
x[2]=
x[3]=
x[4]=
Fill in these values. Now apply the formula you listed above to find the DFT (come on, it's only 5 values!)
X[0]=
X[1]=
X[2]=
X[3]=
X[4]=
So am I right in saying
x[0]=1
x[1]=0
x[2]=-1
x[3]=0
x[4]=1
for a cosine wave?
x[0]=1
x[1]=0
x[2]=-1
x[3]=0
x[4]=1
for a cosine wave?
Yes, that's correct. A sine wave starts at 0, however. I think the answers will differ by an imaginary number in the end (equivalent to a phase shift, if I recall correctly).
Why do you find the x[n] values for a sine wave when the question is asking about a cosine wave?
Huh. I could swear your original post asked for sine. In that case, carry on!
So I would plug those values into the forumula, and then add all of the outputs together?
Yup. And now?
X[0]=
X[1]=
X[2]=
X[3]=
X[4]=
26K
