Eigenvalues and Eigenvectors of 2x2 Matrix | Homework Help
  • Thread starter Thread starter hex.halo
    Eigenvectors
The discussion focuses on finding the eigenvalues and corresponding eigenvectors of the matrix [1,1;1,1], with the eigenvalues determined as e1=2 and e2=0. Participants explain the process of substituting these eigenvalues back into the matrix equation to find eigenvectors, emphasizing that any scalar multiple of an eigenvector is also valid. It is noted that the set of eigenvectors corresponding to a given eigenvalue forms a subspace, which can have infinite vectors. Additionally, for matrices larger than 2x2, the eigenvalue's eigenspace may have a dimension greater than 1, requiring careful selection of variables to find independent basis vectors. Understanding these concepts is crucial for solving eigenvalue problems effectively.
hex.halo
Find the eigenvalues and correspointing eigenvectors of the matrix:
[1,1;1,1]
I can solve the determinant to get the eigenvalues: e1=2, e2=0, and from here I am supposed to sub these values back into my matrix and find the eigenvectors, right? I'm not sure how to perform this process though...
hex.halo said:
Find the eigenvalues and correspointing eigenvectors of the matrix [1,1;1,1]
I can solve the determinant to get the eigenvalues: e1=2, e2=0.
Hi hex.halo! :smile:
The standard way (which you must be able to do): just write [1,1;1,1](a,b) = (0,0), and solve; and the same for [1,1;1,1](a,b) = (2a,2b). :smile:
(And the shortcut in this case: the eigenvectors for M + a.I are the same as for M, for any matrix M and any number a … so just look for the eigenvectors of [0,1;1,0], which you can probably guess! :smile:)
Some people (on this board) use a "complicated method" of putting the eigenvalues into the matrix A-\lambda I and row reducing but I much prefer tiny-tims method: any eigenvector, by definition, must satisfy Av= \lambda v. Set up that equation and solve for v.
For example, with eigenvalue 2, you must solve
\left[\begin{array}{cc}1 &amp; 1 \\ 1 &amp; 1\end{array}\right]\left[\begin{array}{c} x \\ y\end{array}\right]= \left[\begin{array}{c} 2x \\ 2y\end{array}\right][/itex]<br /> You will NOT be able to solve for both x and y, only for y, say, as a function of x because any multiple of an eigenvector is also an eigenvector. Choose any convenient value of x, calculate the corresponding y, and any eigenvector is a multiple of that.
¿ "board" ?​
oh … do you mean "planck" … ? :biggrin:
(:confused: I take two!)
So, you're telling me that I need to solve y in terms of x from that (very nice) matrix set up, then I can sub in ANY number for x that I want to get my eigenvector and have the right answer? Wouldn't this result in an infinite number of correct eigenvectors? Actually, don't worry about that, I imagine i'll have that explained to me at some point. What I'd really like to know is, for any question, am I right to sub in 1 for my x value then just put a scalar multiple out the front of the matrix to represent all the multiples and that would be correct?
Yes, of course! If v is an eigenvector corresponding to eigenvalue \lambda, then so is any number times v. The set of all eigenvectors corresponding to a given eigenvalue forms a subspace! That always has an infinite number of vectors.
Yes, if you choose anyone of the vectors in the (one-dimensional) subspace, any other can be written as a multiple of it. You can choose x (or y and then solve for x) to be any number you please. "1" seems like a simple choice!
It is possible that the set of eigenvectors corresponding to an eigenvalue is a subspace of dimension larger than 1. For a 2 by 2 that would of course be all of R2. In that case that the matrix is larger than 2 by 2, with a single eigenvalue having "eigenspace" of dimension greater than 1, solving the equation Ax= \lambda x would give an equation where other variables depend on two (or more) of the variables. In that case, taking them to be 1 and 0, then 0 and 1 should give you independent basis vectors for the subspace.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 19 ·
14K
