Help with elasticity/stretching&compression
  • Thread starter Thread starter Nellen2222
A force stretches a wire by 1.0 mm, and a second wire of the same material, with double the length, will stretch by 2.0 mm under the same force. The relationship between stretch and length is directly proportional, as derived from Young's modulus. For the third wire, which has the same length as the first but twice the diameter, the cross-sectional area increases, affecting the stretch. The equations for both scenarios can be set up using the same principles of elasticity, allowing for straightforward calculations. Understanding the differences between Young's modulus, shear modulus, and bulk modulus is essential, as they apply to different material responses under stress.
Nellen2222
A Force stretches a wire by 1.0mm A second wire of the same material has the same cross section and twice the length. How far will it be stretched by the same force?
b) A third wire of the same material has teh same length and twice the diameter as teh first. How far will it be stretched by the same force?
F = y(delta)L/L0*A Youngs modulus
1.0mm = 0.01m
I believe you have to compare the original youngs mudulus with one that is slightly different... I need some guidelines on how to solve this mathematically please. Also, on a side note, is there a differnence between Youngs modulus/shears modulus/bulk modulus? or all they all aprt of the same idea with different concepts, ie(one uses volume)
Thanks
No the material is the same so the youngs modulus should be the same.
Try this approach..
F = -EA0ΔL/L0
E is the Young's modulus (modulus of elasticity)
F is the force exerted on an object under tension;
A0 is the original cross-sectional area through which the force is applied;
ΔL is the amount by which the length of the object changes;
L0 is the original length of the object.
So write two versions of the above one for the short wire (subscript s) and one for the long wire (subscript L). The youngs modulus, the cross sectional area and the force are the same for both lengths of wire..
F = -EA0ΔLs/Ls
F = -EA0ΔLL/LL
Since the force is the same you can equate the two...
-EA0ΔLs/Ls = -EA0ΔLL/LL
The youngs modulus and the cross sectional area cancel leaving..
ΔLs/Ls = ΔLL/LL
Then rearrange to give...
ΔLL/ΔLs= LL/Ls
In other words the amount of stretch (ΔL) increases in the same ratio as the length (L) increases. eg Double the length and the amount of stretch is also doubled (all else being equal).
If
LL/Ls = 2
then
ΔLL/ΔLs = 2 Part 2 can be tackled in a similar way. Write two equations with different "A". Note that in this case the length L, the force F and the youngs modulus is the same for both.
  • · Replies 21 ·
