Calculating ΔH Using Hess's Law for FeO(s)CO(g) Reaction
  • Thread starter Thread starter Specter
    Law
The discussion focuses on calculating the enthalpy change (ΔH) for the reaction FeO(s) + CO(g) → Fe(s) + CO2(g) using Hess's Law. Participants identified issues with the provided reactions, specifically that the first equation is unbalanced and does not include FeO(s) or Fe(s). A suggested approach involves defining the formation enthalpies of each substance and forming equations to solve for the unknown ΔH. The importance of correctly writing state symbols as per IUPAC standards was also emphasized.
  • Understanding of Hess's Law and its application in thermochemistry.
  • Knowledge of enthalpy change (ΔH) and formation enthalpies.
  • Familiarity with balancing chemical equations.
  • Proficiency in using algebra to solve systems of equations.
  • Research how to balance chemical equations effectively.
  • Learn about Hess's Law and its applications in calculating ΔH.
  • Study the concept of standard enthalpy of formation for various substances.
  • Explore methods for solving systems of equations in chemistry.
Chemistry students, educators, and anyone involved in thermodynamics or chemical reaction analysis will benefit from this discussion.
Specter
Using Hess's law, calculate the ΔH value for the following reaction:
FeO(s)CO(g)→Fe(s)+CO2(g)
Use these three reactions:
1. Fe2O3(s)+3CO(g)→2Fe3O4(s)+CO2(g) ΔH= -25.0 kJ
2. 3Fe2O3(s)+CO(g)→2Fe3O4(s)+CO2(g) ΔH= -47.0 kJ
3. Fe3O4(s)+CO(g)→3FeO(s)+CO2
ΔH= +38.0 kJ
This is what I have done so far:
Reversed reaction 3
3FeO(s)+CO2→Fe3O4(s)+CO(g) ΔH = -38.0 kJ
I've tried some other things but each time I get the incorrect answer. The examples that I was shown were way easier than this.
I'm not really sure what to do next. I reversed reaction 3 to get FeO on the left side. Any help on the steps I should take to complete this would be great... I find this question very confusing.
Your first step is definitely a correct one.
Hard to comment on your attempts (and why they yielded incorrect answers) not seeing them.
As there is an obvious mistake in the problem wording (first equation is not balanced, neither of the 1st and 2nd equation contains FeO(s), and there is no Fe(s) present anywhere) it is also impossible to point you in the right direction.
Note: state symbols (s), (aq), (g) and (l) should be not written as subscripts. It is a common error, present even in textbooks, but IUPAC defined them to be written with normal characters.
Hi,
If I were you, I would try the following:
Call ΔΗformation of each substance x (ΔΗf, Fe3O4), y (ΔΗf, CO2), z (ΔΗf,Fe2O3), v (ΔΗf, CO), k (ΔΗf, FeO). Then I would form 3 equations with 5 unknown variables.
In order to find the unknown ΔΗ, I would search to find the value of (y-k-v). Perhaps, this is not impossible, since you relate the 3 unknown variables in a 3x5 system.Then, ΔΗunknown=y+ΔΗFe-k-v (ΔΗFe is considered given data-you can find it from the web).
This way, I would transform the chemical problem into a mathematical problem, but still I don't know if it is possible/easy/difficult to find the value of (y-k-v).
Edit Note : I agree with Post #2. There are problems with the equations that will make it impossible to solve the problem.
I did write it wrong, sorry about that. Is there any way I can have this thread deleted so that I can create a new one with the correct information? Also, thanks for letting me know about state symbols, in my lesson they are written as subscripts but I will write them as normal characters from now on.
Post the correct information and we will edit the original post, marking things that were modified.
27K
  • · Replies 17 ·
17K
10K
