Comp Sci Help with Java program calculation
The discussion revolves around a Java program intended to convert 22 square meters into square kilometers. The key issue identified is that the program incorrectly performs integer division, resulting in a value of zero. To resolve this, it is suggested to declare either the square meter or kilometer rate as a double to ensure proper calculation. Additionally, the program is criticized for displaying an uninitialized variable and for including unnecessary statements. The correct implementation will yield a non-zero result for the conversion.
Darkstar3000
Question: Write a program to convert 22 square metres into square kilometres.
Note: divide square metres by 1 million to produce square kilometres.
Note also that the answer is not zero!
I know the note says the answer is not zero but shouldn't it have some value other than 0 ?
My code
Code:
public class areaConverter{
public static void main(String []args){
    long kilometrerate = 1000000;
    int sqmetre = 22;
    double sqmtosqk;
    sqmtosqk = sqmetre/kilometrerate;
    System.out.println("The number of square Kilometres in "+sqmetre+" square meters is " + sqmtosqk);
My code
Code:
    int sqmetre = 22;
    double sqmtosqk;
Hint : Declare sqmetre or kilometrerate double rather than long or int.
You have written too many statements that were not even required.
The main problems are that your program
1) does no calculations
2) displays an uninitialized variable, sqmtosqk
