Understanding the Science of Compressed Water: A Deep Dive with Bob
  • Thread starter Thread starter capnahab
    Liquid Water
Water is generally treated as incompressible for simplicity, but it is actually compressible, with a notable compression of about 13% at 60K PSI during water jet cutting. When water is compressed, it does heat up, but it can subsequently cool down, which is relevant to its phase changes. The freezing of water at approximately 150K PSI is linked to specific conditions on the phase diagram, indicating that pressure and temperature influence its state. The concept of latent heat is often misunderstood, as it relates to phase transitions rather than just temperature changes. Understanding these principles clarifies the behavior of water under extreme pressure conditions.
capnahab
Sirs, I have always understood that water cannot be compressed but I have been informed by competent people that it can. We use water jet cutting at 60KPSI and I am told that this water compresses by 13%. While I can accept this I do not understand why at app. 150K PSI the water freezes and that pressure is the limit. It seems to me that compressed water should gain heat and not get colder. Would you gentlemen/gentlewomen please explain? Old science nut, Bob
For many purposes, you assume water to be incompressible just to simplify problems, but it is actually compressible.
And yes, if you compress it it heats up, but you can then let it cool back down. Whether it freezes or not at a certain temperature and pressure depends on where that is on the phase diagram: http://www.lsbu.ac.uk/water/phase.html
Thank you for the phase diagram. They always told me it was latent heat but I could never understand latent heat. I always thought that is was phase transistion. Too many words do decscribe the same thing.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
