Help with plastic bridge design
The discussion revolves around a high school Precalculus project involving the design and construction of a bridge using PVC and twine. The objective is to create a bridge that can support a significant amount of weight, with constraints including a limited amount of materials and a specific design requirement for an arch bridge.
  • Exploratory, Conceptual clarification, Problem interpretation, Assumption checking
  • Participants discuss various design ideas, including the use of arches and additional support structures. Questions arise about effective jointing methods and the implications of load distribution on the bridge's performance.
Participants are actively sharing ideas and seeking input on their designs. Some have begun to formulate specific concepts while others are exploring foundational principles of bridge design. There is an ongoing exchange of thoughts regarding material properties and structural integrity.
Constraints include the requirement to use PVC or a similar flexible plastic, the allowance for drilling holes in the pipes, and the need to meet an unstated length for the main portion of the bridge. The previous year's bridge performance is also referenced as a benchmark for weight capacity.
Tesla42
I am in a high school Precalculus class. We are about to have a project where we build bridges with PVC and twine. The goal is to hold as much weight as possible.
For this project, I believe we will be given 28 feet of PVC, a roll of twine, and 5 or 6 days to design and construct our bridges. Also, I think we are designing arch bridges, where there is a main part and a parabola rising above it on each side. Another constraint to the design is that the main portion has to be a certain, so far unstated length in order to reach two blocks so that it can be loaded with weight.
All that said, the purpose in this thread was to receive input from the experts that frequent this website. My teacher told us to do as much research as possible, so I am asking you as well as searching for online resources regarding bridge building.
Thanks in advance for your responses.
I apologize for my inattention to the categories on this forum and my misplaced entry. This would definitely fall under the category of coursework and should be designated as such.
Also, my ideas regarding this bridge are relatively simple right now. I only know that I am going to place two arches and that there will be several lengths of pipe going across the main structure to better handle the stresses that it will go through.
To put into perspective how much this design needs to hold, the top bridge from last year held 292.5 pounds, and that was with 4 fewer feet of plastic. This is around the amount that I want my bridge to hold so that I can get a good grade.
I will be back with some more specific ideas later after researching more about how bridges are designed.
Never built one from PVC only balsawood. I would experiment with methods of jointing. For example think about how you might make triangles out of PVC pipe. It's a lot easier to lash together rough wooden poles than smooth PVC tubes. Can you drill holes in the pipe or are there other restrictions?
Perhaps also find out how they plan to load the weight onto the bridge (eg point loading in the middle or nice uniform distribution?).
We have to build it out of PVC, or at least some type of plastic that is similar. Whatever it is, it is very flexible.
We are allowed to drill holes in the pipes, so connecting joints is far more feasible. Also, I am not sure about how the load will be distributed, but am I correct in assuming that a load more distributed along the span of the bridge would be preferable to a huge load in the bridge's center?
I have formulated a design but I have quite a bit of leftover pipe. Would it be useful or a waste to use the leftover pipe to reinforce the two pipes that form the main span? If it would be a waste, what would be a better suggestion?
10K
