What Is the Tension in the String as the Hoop Descends?
  • Thread starter Thread starter jjlandis
    Tension
The discussion focuses on calculating the tension in a string as a hoop descends. The hoop has a radius of 0.0800 meters and a mass of 0.344 kg. The initial attempt at solving the problem incorrectly used impulse instead of the moment of inertia, which should be m*R² for a hoop. The correct approach involves relating the tension to the hoop's translational and angular accelerations, leading to the conclusion that the tension is m*(g/2). The final calculated tension in the string is 1.686 N, correcting the earlier miscalculation of 1.12 N.
jjlandis
A string is wrapped several times around the rim of a small hoop with radius 0.0800 meters and mass 0.344 kg. If the free end of the string is held in place and the hoop is released from rest calculate the tension in the string while the hoop descends as the string unwinds. Give your answer in Newtons to the third decimal place.
\Sigma Torque = (Tension)*(Radius) = (Impulse)*(angular acceleration) = (1/2)*(Mass)*(Radius2)*(angular acceleration)
I tried to derive the solution down to, Tension = (1/3)*(mass)*(g) but I am not returned with the correct answer. I calculated 1.12 N and the correct answer states 1.686 N
First of all I is not impulse, it's the moment of Inertia. And the moment of inertia for a hoop would be m*R2 not 1/2*m*R2 because the mass is at the rim, not evenly distributed across a solid disk.
Secondly you have the right idea.
T*R = I*α
But T here will be m*(g - a) where a is the translational acceleration (vertical).
And α is the angular acceleration that can be expressed as a/R.
Rewriting then and substituting
m*(g - a)*R = m*R2*a/R
m*g*R - a*m*R = a*m*R
So ...
a = g/2
And so ...
T = m*(g - g/2) = m*g/2
14K
  • · Replies 19 ·
  • · Replies 19 ·
