Find Distance and Bearing from City A to C | Plane Navigation Problem
  • Thread starter Thread starter Phyzwizz
    Bearing Trig
The discussion revolves around calculating the distance and bearing from city A to city C in a plane navigation problem. The distance from A to C has been determined to be approximately 1220.671 miles. Participants suggest using trigonometric ratios to find the bearing by analyzing the coordinates of point C derived from the movements from A to B and B to C. The coordinates for C are calculated as X ≈ 1217.153 and Y ≈ 140.723, which help in determining the angle at A. The conversation highlights the importance of visualizing the problem with right triangles and applying trigonometric functions effectively.
Phyzwizz
Problem
Distance:
From city A to city B, a plane flies 650 miles at a bearing of N 48° E. From city B to city C, the plane flies 810 miles at a bearing of S 65° E. Find the distance from A to C and the bearing from A to C.
Work so far
So far I've gotten the distance from A to C already, but I'm having trouble figuring out what to do, to find the bearing. Its sort of difficult to show what I did to get the sides because it involves drawing a series of other triangles and finding the lengths of some of their sides and adding them in some places and subtracting in others. But the tactic I took in solving for the length was setting A to (0,0) and attempting to find the x and y coordinates for C separately.
What I got for the distance from A to C is, AC≈ 1220.671.
Thanks, I hope someone can help me.
What did you get for the coordinates of C? Just draw one right triangle with hypotenuse AC.
The bearing is just the angle at A between North and AC. In the right angled triangle with AC the hypotenuse, you know two lengths, so you can use trig ratios to find the angle.
The coordinates I got for C are...
X - ≈1217.153 came from (650cos 42°)+(810cos 25°)
Y - ≈140.723 came from (650sin 42°)-(810sin 25°)
Oh, thanks Vertigo, I guess I just need to think about the problem a little more next time. That really is pretty simple.
I just do sin θ = opp/hyp and then I can switch it and make it arcsin opp/hyp= θ right?
θ=theta
opp= opposite
hyp= hypotenuse
That's okay, I'm sure you'll find these questions quite easy from now on. And I'm sure you'll learn soon in class more about arcsin and quadrants and such.
