Help with this emu8086 assembly language problem please
20 replies · 7K views
chewi
Summary:: my code has been successfully showing the right decrement of the letter. however, i tried to put space in between the letter output but its output became repititive letters.
this is the original output
when i try to put space it become like this
i want to put spaces on the output sequence, as well as make the output letters upper case
Code:
.model small
.code
       org   0100h
       call  clr_regs
       jmp   drill_exer2
.data
       first_char       db ?
       stop_char        db ?
       text1            db 10,    "Enter start letter (lowercase letter only): "  ,20h, "$"
       text2            db 13,10, "Enter last letter (lowercase letter only):  "  ,20h,  "$"
       text3            db 13,10, "Output sequence: "  ,20h,  "$"
drill_exer2:            lea     dx, text1
                        call    disp_string
                        call    read_char
                        mov     first_char, al
                        lea     dx, text2
                        call    disp_string
                        call    read_char
                        mov     stop_char, al
                        lea     dx, text3
                        call    disp_string
                        mov     dl, first_char
       next_char:       call    print_char
                        call    disp_del
                        dec     dl
                        cmp     dl, stop_char
                        jne     next_char
                        call    exit
print_char              proc    near
                        mov     ah, 02h
                        int     21h
                        ret
print_char              endp
disp_string             proc    near
                        mov     ah, 09h
                        int     21h
                        ret
disp_string             endp
read_char               proc    near
                        mov     ah, 01h
                        int     21h
                        ret
read_char               endp
clr_regs                proc    near
                        xor     ax, ax
                        xor     bx, bx
                        xor     cx, cx
                        xor     dx, dx
                        ret
clr_regs                endp
exit                    proc    near
                        mov     ah, 4ch
                        int     21h
                        ret
exit                    endp
disp_del                proc    near
                        mov     cx, 000fh
            del:        nop
                        loop    del
                        ret
disp_del                endp
end                     drill_exer2
Could you post your code, and say something about what it is intended to do?
[CODE title="original code"]
.model small
.code
org 0100h
call clr_regs
jmp drill_exer2
.data
first_char db ?
stop_char db ?
call disp_string
call read_char
mov first_char, al
lea dx, text2
call disp_string
call read_char
mov stop_char, al
lea dx, text3
call disp_string
mov dl, first_char
call disp_del
dec dl
cmp dl, stop_char
jne next_char
call exit
mov ah, 02h
int 21h
ret
print_char endp
mov ah, 09h
int 21h
ret
disp_string endp
read_char proc near
mov ah, 01h
int 21h
ret
read_char endp
clr_regs proc near
xor ax, ax
xor bx, bx
xor cx, cx
xor dx, dx
ret
clr_regs endp
exit proc near
mov ah, 4ch
int 21h
ret
exit endp
disp_del proc near
mov cx, 000fh
del: nop
loop del
ret
disp_del endp
end drill_exer2[/CODE]i want to put spaces on the output sequence, as well as make the output letters upper case
In reverse order of what you asked:
Subtract 32 (0x20) from each lowercase letter to get its uppercase equivalent. (Assuming you're working with ordinary ASCII letters.)
The ASCII code for 'a' is 97 (0x61); the ASCII code for 'A' is 65 (0x41).
After you print each character, then print a space character, ASCII 32 (0x20).
i tried to put print space character but the output becomes the 2nd picture attached. what could seem to be the problem?
Please show the modified code, too, so that we can see exactly how you "tried to put print space character" and got the result that your second picture shows.
So is the idea that if the first character entered is 'z' and the last character is 'a', the output should look like this?
Z Y X <etc.> D C B A
It looks like you are getting the space inserted but something else is wrong. One thing I noticed is that your disp_del routine is bogus -- all it does is iterate 15 times, doing nothing else. Since it's not doing anything useful, it should be removed.
Code:
disp_del                proc    near
                        mov     cx, 000fh
            del:        nop
                        loop    del
                        ret
disp_del                endp
My advice for you is to take a step back, and make a better plan for your algorithm. Based on the first character entered and the next character entered, your program should figure out how many iterations of a loop it will need to use to print the sequence of characters.
sysprog said:
<snip> and say something about what it is intended to do?
Yes, I agree with this. It isn't clear what problem you are trying to solve.
[CODE title="modified code"]
.model small
.code
org 0100h
call clr_regs
jmp drill_exer2
.data
first_char db ?
stop_char db ?
call disp_string
call read_char
mov first_char, al
lea dx, text2
call disp_string
call read_char
mov stop_char, al
lea dx, text3
call disp_string
mov dl, first_char
mov dh, dl
call print_space
call disp_del
mov dl, dh
dec dl
cmp dl, stop_char
jne next_char
call exit
mov ah, 02h
int 21h
ret
print_char endp
mov ah, 09h
int 21h
ret
disp_string endp
read_char proc near
mov ah, 01h
int 21h
ret
read_char endp
clr_regs proc near
xor ax, ax
xor bx, bx
xor cx, cx
xor dx, dx
ret
clr_regs endp
exit proc near
mov ah, 4ch
int 21h
ret
exit endp
disp_del proc near
mov cx, 000fh
del: nop
loop del
ret
disp_del endp
print_space proc near
mov dl, 20h
call print_char
ret
print_space endpend drill_exer2[/CODE]
Code:
disp_del                proc    near
                        mov     cx, 000fh
            del:        nop
                        loop    del
                        ret
disp_del                endp
This looks to me like it's intended as a mini-template for doing something efficacious, as in:
Code:
disp_del                proc    near
                        mov     cx, 000fh     ; modify this as required for loop count
            del:        nop                   ; insert code here
                        loop    del
                        ret
disp_del                endp
im sorry if i wasnt really clear with what i say. we just started lesson with this assembly language ang I am having hard time understanding the functions and how really the algorithms work. i hope you all understand
It's ok, we were all beginners once.
Why call print_char from print_space? If you decide to, rather than in the main routine load a space and then call print_char, instead use a procedure that is specific to the space character, then why not issue the interrupt within that called procedure? ##-## as in:
[CODE title="snippet"]
mov dl, 20h ; character is 0x20, i.e. a space
mov ah, 02h ; set request to 'display character'
int 21h ; issue i/o interrupt
ret
print_space endp
[/CODE]
@Mark44, @sysprog, Most likely it is a delay loop for the display, probably to give the display time to actually display between characters. (although it should probably be called after every character, and would ideally be in the display driver and/or the operating system :wink:)
@chewi, Try drawing a picture (a flow chart) of the operations in "drill_exer2:" (lines 16 thru 37).
Flow chart symbols and their definitions are at https://www.gliffy.com/blog/guide-to-flowchart-symbols, for starters you only need the first 4 symbols for this. Be sure to include every line of code in the drawing, and add comments as needed that explain what the step is trying to accomplish. Then step thru (follow) the drawing to check what the computer is being told to do.
This approach is a great help in understanding programs because our brain tends to process pictures 'in parallel', that is we can get a better overall view of things and how they interact.
Hope this helps!
Cheers,
Tom
p.s. The problem seems to be one of those things all of us forget sometimes, even after decades of programming!
EDIT:
p.p.s. The Technical Reference for the operating system (MSDOS) shows that the contents of the CPU registers upon return from the INT 21H call are "NONE" (what was in them going in is not necessarily still there)!
I think that you're right about this ##-## I thought of the fact of the program being an exercise, rather than thinking of it running on an 8086 ##-## your explanation squares with the name of the subroutine, too.
Tom.G said:
EDIT:
This is not true. int 21H saves all registers. The first program obviously did use dl after the int21h.
Note that print_space overwrites dl, and dl is saved in dh only once, and not before every call to print_space
In the modified code, dh is copied to dl after the call to print_space and before dl is decremented ##-## dh should also be decremented at that point.
thank you so much this fixed the repititive outputs, i wonder where should i put th sub to make the output uppercase
Probably true but the name threw me off. I interpreted "disp_del" to have something to do with deletion rather than delay, as "del" is a much more common abbreviation for "delete." Two more letters in the label name and/or a comment would have been helpful.
In any case, I'm not sure how much a delay loop that executes only 15 times would slow down the display. I don't have an 8086 emulator, and I haven't written any code that uses the old DOS int 21h functionality since Windows went from 16 bits to 32 bits back in the 90s.
Flow charts are pretty much passe these days, with pseudocode being the preferred way to lay out the high-level operations of some code. However, I agree that a flow chart wouldn't hurt, in the absence of pseudocode.
The thread put me in mind of what the instructor in a CS class said one time -- "The sooner you sit down to the keyboard, the longer it takes to write your program."
Assuming that you are no longer calling print_char from print_space, you can do the uppercase conversion in print_char ##-## if you try to uppercase a space you'll get a null.
Subtracting 0x20 from the byte, as @Mark44 said, will convert a lowercase ASCII letter to uppercase ##-## the letter 'a' differs from the letter 'A' only in that the 6th bit from the right is 1 in lowercase and 0 in uppercase.
That means that instead of usingsub dl, 20h[/size] you could also instead useAND dl, 11011111b[/size] thus switching the 6th bit off while leaving the other bits unchanged.
sysprog said:
That means that instead of usingsub dl, 20h you could also instead useAND dl, 11011111b thus switching the 6th bit off while leaving the other bits unchanged.
Yes this is the standard method for uppercasing: it has the advantage over subtraction that uppercase letters are unchanged i..e both A and a map to A (and similarly for lowercasing OR 20h is preferable to ADD 20h). Note however that the bit with the place value ## 20_{16} = 2^5 ## is usually called bit 5, not bit 6.
pbuk said:
Yes this is the standard method for uppercasing: it has the advantage over subtraction that uppercase letters are unchanged i..e both A and a map to A (and similarly for lowercasing OR 20h is preferable to ADD 20h). Note however that the bit with the place value ## 20_{16) = 2^5 ## is usually called bit 5, not bit 6.
I didn't call it bit 6; I first called it the 6th bit from the right, and after that, the 6th bit ##-## if the convention is to designate the bit by its offset, rather than by its position within the byte (i.e. 'the bit at offset 5', rather than 'the bit at position 6'), then yes, the first bit is 'bit 0' (short for 'the bit at offset 0'), and the 6th bit is 'bit 5' ##-## I think that it's more perspicuous to call it the 6th bit.
@pbuk, it seems that there's a different convention in some IBM usage ##-##
From https://www.ibm.com/docs/en/z-netview/6.2.0?topic=notations-using-bit-notation
Using Bit Notation​
Last Updated: 2021-04-15​
Another option is to specify a bit position. With a bit position, the rules of the comparison change, and the item you specify on the right side of the expression must be a bit string. Like byte positions, bit positions begin at one (1) rather than zero (0). (emphasis added)​
