HELPConservation of momentum lab
  • Thread starter Thread starter pie877
    Lab Momentum
The discussion revolves around a lab experiment involving the conservation of momentum and kinematics, where participants are tasked with determining the velocity of a film canister propelled by a chemical reaction. The original poster shares specific measurements and equations relevant to the problem, including the mass of the canister and its contents, the time of flight, and the maximum height achieved.
  • Participants discuss the application of kinematic equations and the conservation of momentum, questioning the necessity of using the momentum equation in this context. There is also exploration of energy conservation principles, specifically kinetic and potential energy.
The discussion is active, with participants offering guidance on which equations to use and clarifying the mass considerations for energy calculations. There is an ongoing exploration of the correct approach to the problem, with no explicit consensus reached yet.
Participants are navigating the constraints of the lab setup and the specific measurements provided, including the total mass of the canister and its contents, as well as the time and height data. There is uncertainty regarding which mass to consider for energy calculations.
pie877
1. we did a lab putting baking soda, citric acid, and water into a film canister and we had to find the amount of each ingrediant to give the max height when propelled by material, and once we have that we time it and the questions is to find the velocityof the canister when the propellant erupts
m (of canister) 4.1g
m (of baking soda, citric acid and water) 7g
m (of water) 10 ml (10 g)
time (from liftoff to landing) 1.29 s
max height 6m
we know the basic kinematics equations such as:
d=v1t+1/2at^2
v2^2=v1^2 + 2ad
also we know conservation of momentum equation
p1=p2
m1v1+m2v1+m3v3=m1v'1+m2v'2+m3v'3
3. The Attempt at a Solution
i tried using the 1st equation d=v1t+1/2at^2 but my speed was 12.6
when t=.645s (time to reach max height) and a=9.8m/s^2 and d=6 m (max height)
but I am not sure if we need to use the momentum equation? and how t go about to this lab?
welcome to pf!
hi pie877! welcome to pf! :smile:
(try using the X2 and X2 icons just above the Reply box :wink:)
no, energy will do …
either use KE + PE = constant,
or use one the standard constant acceleration equations (not d = v1t + 1/2at2, it has too many unknowns, use one with v2 in … I'm assuming the canister is going straight up :wink:)
Hi pie877, welcome to PF :)
(Please refrain from using bold face - it hurts my eyes!)
max height 6m
Can you explain how you found a speed of 12.6 when t=.645s?
Btw, the momentum equation is not of use in this case.
Alright I'll try that and yes it's going straight up
Thx
should i get the same answer tho?
cuz I am not sure which mass to use for KE+PE=constant
like mass of canister or mass of canister and contents lol
hi pie877! :smile:
(just got up :zzz: …)
use the mass of whatever goes up …
any contents that get left behind don't count :wink:
Thanks I got it to work lol :)
  • · Replies 19 ·
  • · Replies 31 ·
