Hermiticity of permutation operator
9 replies · 7K views
issacnewton
Hi
here's a problem I am having.
Consider the hilbert space of two-variable complex functions [tex]\psi (x,y)[/tex].
A permutation operator is defined by its action on [tex]\psi (x,y)[/tex] as follows.
[tex]\hat{\pi} \psi (x,y) = \psi (y,x)[/tex]
a) Verify that operator is linear and hermitian.
b) Show that
[tex]\hat{\pi}^2 = \hat{I}[/tex]
find the eigenvalues and show that the eigenfunctions of [tex]\hat{\pi}[/tex] are given by
[tex]\psi_{+} (x,y)= \frac{1}{2}\left[ \psi (x,y) +\psi (y,x) \right][/tex]
and
[tex]\psi_{-} (x,y)= \frac{1}{2}\left[ \psi (x,y) -\psi (y,x) \right][/tex]
I could show that the operator is linear and also that its square is unity operator I . I did
find out the eigenvalues too. I am having trouble showing that its hermitian and the
part b about its eigenfunctions.
Any help ?
After you already show that [itex]\hat{\pi}[/itex] is linear. Take a look at [itex]\hat{\pi}^2[/itex]. What is it? From this what can you infer about the possible eigenvalues for [itex]\hat{pi}[/itex]? What properties for the eigenvalues for an operator implies Hermiticity?
Hi , eigenvalues are [tex]\pm 1[/tex] they are real. I know that hermitian operators have real eigenvalues but does it mean that if operator has real eigenvalues then its a hermitian
operator ( this is converse statement , so not necessarily true) ?
If all the eigenvalues of an operators are real.
More explicitly, you are trying to show that:
[tex]\int_{-\infty}^{\infty} \psi(r)^{*} \phi(-r) dr = \int_{-\infty}^{\infty} \psi(-r)^{*} \phi(r) dr[/tex]
which is easy by simple change of variable.
So since all eigenvalues of [itex]\hat{\pi}[/itex] are real , its hermitian. fine that's solved.
what about the second part about the eigenfunctions ? can you help ?
vela, yes that's one approach. but how do I derive these eigenfunctions in the first place ?
There are really no general approach for arbitrary operator. A good guess is a start.
I suppose you could make a hand-waving argument that the Hilbert space can be written as a direct sum of subspaces, where each subspace is the span of Φ(x,y) and Φ(y,x) for a particular Φ(x,y). Then find the matrix representing [itex]\hat{\pi}[/itex] in one of these subspaces and diagonalize it. Blah, blah, blah...
It's more useful, though, to recognize this pattern of combining elements to achieve a certain symmetry.
thanks fellas. makes some sense now...
