High altitude balloon gas expansion
3 replies · 7K views
Gmanme
Could someone help me calculate the rate of expansion of gas (helium or hydrogen) in a balloon at different altitudes.
temperature is -30f at all altitudes
http://www.engineeringtoolbox.com/air-altitude-pressure-d_462.html <- chart for air pressure
What would the diameter of a balloon filled with helium OR hydrogen be at 30k 60k and 90k feet have to lift 500lbs total.
around 23 ft at sea level
I'm having trouble understanding. Is the balloon rising up at a constant speed? Is it just let go and free to rise? If you suddenly change a balloon's altitude, it would expand or contract because the atmospheric pressure is now different, but the expansion would stop once an equilibrium is reached.
Take the pressures from 30k, 60k and 90k, and find out how big the balloon would have to be to lift a total wieght of 500 lbs at these altitudes.
Well you know the buoyancy required is 500 lbs. You will want to know at each of those pressures how big a volume is needed to supply the difference in weight of the air displaced and helium or hydrogen (choose one) at the same pressure.
Careful of your units.
