Higher-Order Differential Equations
4 replies · 2K views · last reply
recon_ind
Find the general solution of the given higher-order differential equation.
d3x/(dt3) - d2x/(dt2) - 4x = 0
Use an auxiliary equation such as m3 - m2 - 4 = 0
That is the auxiliary equation you want to use. As it turns out, the left side can be factored, yielding (m - 2)(m2 + m + 2) = 0
There are three distinct solutions, so the solution to this homogeneous problem will be x(t) = c1e2t + c2em2t + c3em3t. All you have to do is find the other two constants, m2 and m3.
So, I should just use the quadratic formula to find the other two solutions?
Thanks man.
The other two solutions are of the form [tex]\alpha[/tex] [tex]\pm[/tex] [tex]\beta[/tex]
Yes. And yes, the two solutions are of the form a +/- b. One of your values of m will be a + b, and the other will be a - b.
