The discussion revolves around calculating the power transmitted by a hollow turbine shaft under torsion, given specific parameters such as rotational speed, external diameter, thickness, and maximum shear stress. The focus is on the application of relevant equations and the resolution of discrepancies in calculations.
- Homework-related
- Mathematical reasoning
- Debate/contested
- One participant presents a calculation for power transmitted using the formula T=J*stress/r and expresses confusion over not arriving at the expected result of 66 GW.
- Another participant suggests checking units and questions whether the expected result should actually be 66 MW instead of GW.
- Concerns are raised about the use of diameter instead of radius and the application of the fourth power in torque integration, with one participant emphasizing the need to maintain units with values for clarity.
- Some participants agree on the correctness of using the fourth power in calculations, while others challenge the accuracy of the radius value and the scaling factor of 10^6.
- There is a request for clarification on the correct value for radius and the appropriate scaling factor to use in calculations.
Participants express differing views on the correctness of certain calculations and assumptions, particularly regarding the radius and the scaling factor. There is no consensus on the correct approach or final answer, as multiple competing interpretations and calculations are presented.
Participants highlight potential limitations in the original calculations, including the need for consistent unit usage and the correct application of formulas. Specific mathematical steps remain unresolved, contributing to the ongoing debate.
Students and practitioners interested in mechanical engineering, particularly those dealing with torsion in hollow shafts and power transmission calculations.
