Hello,
I believe the initial Amplitude is one of hellokitty's givens,
"What was the bullet's speed if the subsequent oscillations have an amplitude of 7.10 cm?"
Why is A being solved for?
Edit: I just solved the problem. Perhaps just "solving" for amplitude left some confused, so I will leave some hints.
1. Final steps don't include use of momentum equations, but equations for simple harmonic motion. Think on the reasoning behind this hint, is the ending momentum "constant" or in other words, is there a true "final" portion of there scenario, such as there is when two billiard balls hit each other?
2. When differentiating the position equation for SHM, don't forget the chain rule! (There is an important constant inside the trig. function of x(t))
3. After solving for the initial velocity of the mass and plugging that into v(t), look at the variable you wish to solve for and ask yourself how you may get rid of any other unknown constant.
It may be helpful to think of this as a three-stage momentum problem involving SHM.
You have:
Stage 1: The bullet is moving, block is at rest.
Stage 2. The instant when the block is hit by the bullet
Stage 3: System is now modeled by SHM; momentum is constantly changing with respect to the block's distance from the equilibrium point.
I hope this was helpful :)
