Homopolar Motor: Energy Input, Output, & Magnetic Field
The discussion revolves around the energy input and output of a homopolar motor, focusing on the relationship between the input power, output power, and the effects of the magnetic field on the motor's operation. Participants explore concepts related to energy absorption, kinetic energy conversion, and practical implications of high current usage.
  • One participant questions where the energy imparted into the rotor comes from when the input and output power are equal at 10V and 1000A.
  • Another participant suggests that the input power is derived from the source driving the current through the motor and notes that the output power must be less than the input due to inherent losses.
  • There is a query about whether any power is absorbed and converted into kinetic energy, and if the readings from voltmeters would change due to absorption or other effects.
  • A participant mentions that for an ideal motor/generator, power output equals power input, but acknowledges real-world losses such as friction and resistive heating.
  • One participant specifically asks for the power consumed by the rotor and requests an equation to quantify it.
  • Another participant identifies sources of power loss, including friction, resistive heating, and air resistance, and provides the equation for resistive heating as ##P=I^2R##.
Participants generally agree that real-world motors experience losses, meaning output power is less than input power. However, there is no consensus on the specifics of energy absorption and the exact power consumed by the rotor, as well as the implications of these factors on measurements.
Limitations include the assumptions about ideal versus real-world conditions, the dependence on specific definitions of power in the context of homopolar motors, and unresolved details regarding the measurement of current and voltage at different points in the system.
John Shillington
I was curious in regards to a homopolar motor where the energy imparted into the rotor comes from if the energy input is say 10v at 1000 amps and there is 10v 1000amps output. Aswell if the effect of the magnetic field produces a different power on the rim of the disk vs the input from the central rod.
Science news on Phys.org
The input power comes from whatever we are using to drive a current through the loop of the motor.
How are we getting an output from the motor? Using it to drive a generator? In any case the output power will be less than the input; if we are passing 1000 amps at 10 volts through the loop of the motor, then its usable output must be less than 10kW.
(And as a practical note, a sustained 1000A current is a big scary dangerous thing - I hope that you are doing a thought experiment here, not planning to actually build something).
Thanks for your reply.
The question had more to do with if any of the power through the motor gets absorbed and turned into kinetic energy and if say there where 2 current and voltmeters on where the input is passed verse to where the output is taken from the rim of tge disk if the current and or voltage when being read on the output would be altered at due to said absorption or some other effect.
Im assuming from your answer the power on the side where current flows out of the disk stays just 10kw. Can you clarify that please?
The question had more to do with if any of the power through the motor gets absorbed and turned into kinetic energy and if say there where 2 current and voltmeters on where the input is passed verse to where the output is taken from the rim of the disk if the current and or voltage when being read on the output would be altered at due to said absorption or some other effect.
Yeah, for an ideal motor/generator, the power output equals the power input. In the real world, there are always at least small losses for bearing friction and wire losses, etc., so the power output is always less than the power input.
For example, in my company's previous building, we used a motor/generator to convert 120Vrms @ 60Hz to 240Vrms @ 50Hz for testing the European versions of our products. The medium power motor/generator unit was about 4m^3 in volume, and made an impressive loud humming noise and was always pretty warm. Do you think that the fact that it made noise and was warm might detract from an ideal 100% efficiency? :smile:
I understand that but specifically for a homopolar generator what power is consumed by the rotor? An equation would be appreciated.
There will be friction in the bearings, resistive heating from the current through the wire loop, and (if we aren’t enclosing the whole thing in a vacuum chamber) air resistance. The only one that will have a straightforward equation will be the resistive heating: ##P=I^2R## is the lost power.
  • · Replies 47 ·
14K
