Horizontal force exerted by an engine
The discussion revolves around confusion regarding a homework problem related to horizontal force exerted by an engine. The user attempts to apply Bernoulli's equation to find velocity at two points but encounters an imaginary number for velocity, indicating a potential error. It is suggested that the issue may stem from incorrectly using the universal gas constant instead of the specific gas constant for air. Clarification on the correct value of R is provided, emphasizing the importance of using the appropriate constant in calculations. The conversation highlights the need for careful attention to units and constants in physics problems.
theBEAST
I am only confused about question 2.
I decided to use bernoulli's equation to find velocity at point 1. With velocity at point 1 and point 2 I can use conservation of momentum to solve for the force exerted. In this case there would be Fx, pressure force at 1 and pressure force at 2. However as you can see in my second last and last lines of work, v1 comes out to be an imaginary number which is impossible.
What am I doing wrong?
I think, in the step where you compute the density is wrong, 'cause R's value in the international system of measures is R=8,314 \dfrac{J}{mol \cdot K}
The R in this equation refers to the specific gas constant of air, so it isn't 8.3146 I believe.
Oh, lol ahahahha
